Thanks, Ralph. That is really good advice!
Has any facility built, smoothly deployed and happily used RPM packages for EPICS installation of the base and popular support modules (seq, asyn, motor, streamDevice, etc.)? Please share your repositories (or building rules / specs) and
your experience. Thank you!
The Debian packaging is "near distribution quality": following all applicable guidelines and file system standards, including all necessary legal and license information. The packages would need few changes (if any) to be accepted in the
Debian distribution.
While the packaging tools are different, Fedora / Red Hat guidelines and rules are very similar.
I think it would be best to keep a Red Hat packaging effort as close as possible to the Debian packaging, using the same names, versions, places, techniques. With the Debian packaging and its helper tools as a reference, the way towards
a similar Red Hat packaging should be straightforward. Long term, it would make it easier to apply fixes for problems found on one distribution to the other, improve user experience (packaged EPICS works the same on Debian and RedHat) and hopefully create
a larger group of packaging contributors, which could/should reduce the amount of work for each person. A lot of EPICS places use Red Hat, so I am sure there are others who would help.
My suggestion would be to start working on Red Hat packaging within the epicsdeb project on GitHub that collects the existing Debian packaging. (If the "deb" part of the name becomes an issue, we could rename it at some point.)
Create a workflow / branching model that allows for both packaging efforts to use the same sources and add their specifics without affecting the other.
- RPM packages for EPICS Hu, Yong via Tech-talk
- Re: RPM packages for EPICS Ralph Lange via Tech-talk
Re: Matlab 2020b crashes with labCA 3.7.2 Till Straumann via Tech-talk
<2021>
2025
2026
Re: RPM packages for EPICS J. Lewis Muir via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
