Subject: Re: Larger build products in base-7.0.5
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 30 Apr 2021 11:20:49 -0500
Andrew,
Thanks for the info. You are correct; I don't see the '-g' option in the 7.0.4.1 build, but I do see the '-g' option in the 7.0.5 build.
Kevin
On 4/30/21 10:52 AM, Johnson, Andrew N. wrote:
You can double-check by comparing a gcc or g++ command in the two builds, in 7.0.4.1 you probably won’t see the -g option whereas in 7.0.5 I think you will. Please let us know if that’s not true.
Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
Re: Larger build products in base-7.0.5 Johnson, Andrew N. via Tech-talk
Prev: Re: ADVimba disconnect Mark Rivers via Tech-talk
Next: EPICS 7 base on WSL2 Leblanc, Gregory via Tech-talk
Prev: Re: Larger build products in base-7.0.5 Johnson, Andrew N. via Tech-talk
