Subject: Re: ADVimba disconnect
To: John Dobbins <[email protected]>
Date: Fri, 30 Apr 2021 16:02:07 +0000
Hi John,
The ADVimba driver does not implement the connect() and disconnect() methods to actually disconnect the driver from the camera.  When you do a "disconnect" you are currently only disconnecting the driver from device support, so records won't talk to the driver.
We probably should implement the connect() and disconnect() methods in the driver.  But this has some problems, some of which are discussed in this Github issue for ADAravis:
https://github.com/areaDetector/ADAravis/issues/12
For example, how should ADVimba behave if you do the following:
- Disconnect the camera from ADVimba
- Use their Vimba Viewer software to change some settings
- Disconnect Vimba Viewer
- Reconnect ADVimba
Should ADVimba:
- Pull the new settings from the camera and update the EPICS PVs
or
- Push all of the existing EPICS PV values down to the camera
Neither is trivial to implement.  And this problem is much more general than just ADVimba, or just areaDetector drivers.  Can we make a general solution for EPICS IOCs to handle devices that have been power-cycled or otherwise reset without restarting the IOC?
One thought I had was to use the functions in autosave for this.  autosave is already saving the settings that should be pushed to the device when the IOC starts up.  We could arrange for drivers to optionally push all of those values to the device when it detects or is told that the device has been reset.
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Friday, April 30, 2021 9:21 AM
To: [email protected]
Subject: ADVimba disconnect
All,
Apologies if I have overlooked something in the documentation.
I am using ADVimba 1.1 ADCore 3.7, SDK 1.8
Under asynRecord I select noAutoConnect and then disconnect.  The IOC then reports 'disconnected', however when I then start the Vimba Viewer software supplied by Allied Vision, that software reports the camera as unavailable, i.e. still connected.
Do others see this?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu>
ADVimba disconnect John Dobbins via Tech-talk
Prev: Re: Larger build products in base-7.0.5 Johnson, Andrew N. via Tech-talk
Next: Re: Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
Prev: ADVimba disconnect John Dobbins via Tech-talk
Next: Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
