Subject: Re: Larger build products in base-7.0.5
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>
Date: Fri, 30 Apr 2021 15:52:19 +0000
Hi Kevin,
On Apr 30, 2021, at 9:46 AM, Kevin Peterson via Tech-talk <[email protected]> wrote:
Is there are reason the linux-x86_64 build products of base-7.0.5 are 10x larger than the build products of base-7.0.4.1?
I believe the change occurred when that I moved GCC's -g option that includes debugging symbols in optimized builds from a CONFIG_SITE file where it didn’t work, to those where it does. In your case:
diff --git a/configure/os/CONFIG_SITE.Common.linuxCommon b/configure/os/CONFIG_S
index 7f5d4aa11..2b035eac9 100644
--- a/configure/os/CONFIG_SITE.Common.linuxCommon
+++ b/configure/os/CONFIG_SITE.Common.linuxCommon
@@ -2,10 +2,9 @@
 # Site-specific settings for all linux targets
+# WARNING: Variables that are set in $(CONFIG)/CONFIG.gnuCommon cannot be
+# overridden in this file for native builds, e.g. variables such as
+#   OPT_CFLAGS_YES, WARN_CFLAGS, SHRLIB_LDFLAGS
+# They must be set in the host+target specific file instead:
+#   CONFIG_SITE.<linux-arch>.<linux-arch>
-# It makes sense to include debugging symbols even in optimized builds
-# in case you want to attach gdb to the process or examine a core-dump.
-# This does cost disk space, but not memory as debug symbols are not
-# loaded into RAM when the binary is loaded.
-OPT_CFLAGS_YES += -g
-OPT_CXXFLAGS_YES += -g
diff --git a/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 b/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
index 7a19d0dfe..9178afd43 100644
--- a/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
+++ b/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
@@ -3,4 +3,17 @@
 # Site specific definitions for linux-x86_64 host - linux-x86_64 target builds
+# It makes sense to include debugging symbols even in optimized builds
+# in case you want to attach gdb to the process or examine a core-dump.
+# This does cost disk space, but not memory as debug symbols are not
+# loaded into RAM when the binary is loaded.
+OPT_CFLAGS_YES += -g
+OPT_CXXFLAGS_YES += -g
+# Uncomment the followings lines to build with CLANG instead of GCC.
+#GNU         = NO
+#CMPLR_CLASS = clang
+#CC          = clang
+#CCC         = clang++
The 7.0.5 binaries are also substantially larger than the 7.0.4.1 binaries: 11M vs 1.8M, respectively.
Agreed, but at runtime the differences should be much smaller or zero since the debug symbols don’t get loaded into memory.
You can double-check by comparing a gcc or g++ command in the two builds, in 7.0.4.1 you probably won’t see the -g option whereas in 7.0.5 I think you will. Please let us know if that’s not true.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
Prev: Re: Larger build products in base-7.0.5 Michael Davidsaver via Tech-talk
Next: Re: ADVimba disconnect Mark Rivers via Tech-talk
Next: Re: Larger build products in base-7.0.5 Kevin Peterson via Tech-talk
