Hi Tom, The SCAN field is an enum, i.e. a menu with a limited fixed set of choices. As with all enum/menu fields: If you write a number to it, it will be interpreted as an index into the set of choices. If you write a string, it will be matched against the choice strings. See the Record Reference Manual (https://epics.anl.gov/base/R7-0/4-docs/RecordReference.html) for more details and available choices. Cheers, ~Ralph On Wed, 19 May 2021 at 14:21, Stainer Tom via Tech-talk <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
