Subject: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
From: Heinz Junkes via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Date: Thu, 20 May 2021 17:21:05 +0200
Now I have the curious problem that I have the "normal” rpc.h on my host system (linux-x86_64)
and therefore there with TIRPC=YES then the libtirpc.so of course is not found.
But I have to use the rpcgen of den linux-host to generate the vxi11core_xdr.c
And the host includes of course rpc/rpc.h which is then not found by linux-ppc64e6500.
Heinz
> On 20. May 2021, at 17:03, Hu, Yong <[email protected]> wrote:
> I had the same problem on RHEL8 recently. It was reported here: https://github.com/epics-modules/asyn/issues/95
> If "TIRPC=YES" does not work for your cross compile, then you probably need to comment out all vxi11-related stuff in asyn/asyn/Makefile
> Good luck!
> Yong
> On 5/20/21, 10:43 AM, "Tech-talk on behalf of Pearson, Matthew R. via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
>    Hi,
>    I think I came across the same issue recently on RHEL8. There was a recent Asyn build option added, that you can set in CONFIG_SITE (or CONFIG_SITE.local):
>    TIRPC=YES
>    Which changes the include file search path to /usr/include/tirpc/
>    Cheers,
>    Matt
>    -----Original Message-----
>    From: Tech-talk <[email protected]> On Behalf Of junkes via Tech-talk
>    Sent: Thursday, May 20, 2021 10:22 AM
>    To: Tech talk <[email protected]>
>    Subject: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux
>    I am in the process of cross-compiling EPICS7 for powerpc64-fsl-linux.
>    epics-base works great, also already some support-modules like sncseq, sscan, calc, busy …
>    Now I just fail with asyn on the vxi11 part.
>    rpc/rpc.h can only be found on the yocto-sysroot under usr/include/tirpc. Also I don't see any rpc-support like rpcgen etc..
>    That may also be due to how it was built with yocto. But this part I have not yet understood and I use
>    recipes from ESS and am quite happy where I have now arrived with their help ;-)
>    /opt/ifc14xx/2.6-4.14/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc64-fsl-linux/powerpc64-fsl-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -D_ppc_64_ --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500  -DUNIX  -Dlinux      -O3   -Wall -Werror-implicit-function-declaration     -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD -DHAVE_DEVINT64   -m64 --sysroot=/opt/ifc14xx/2.6-4.14/sysroots/ppc64e6500-fsl-linux -mhard-float -mcpu=e6500 -pipe -feliminate-unused-debug-types      -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         -I/home/yocto/EPICS/epics-support/seq-2.2.8/include -I/home/yocto/EPICS/epics-base/include/compiler/gcc -I/home/yocto/EPICS/epics-base/include/os/Linux -I/home/yocto/EPICS/epics-base/include   -I/home/yocto/EPICS/epics-support/sscan/include   -I/home/yocto/EPICS/epics-support/calc/include  -I/home/yocto/EPICS/epics-support/autosave/include/os/Linux -I/home/yocto/EPICS/epics-support/autosave/include   -I/home/yocto/EPICS/epics-support/busy/include         -I/home/yocto/EPICS/epics-support/motor/include           -c vxi11core_xdr.c
>    In file included from vxi11core_xdr.c:6:
>    vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
>    #include <rpc/rpc.h>
>    compilation terminated.
>    Is there a variable/flag I can use to keep the vxi11 stuff out of the build process of asyn?
>    Danke Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Heinz Junkes via Tech-talk
asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux junkes via Tech-talk
RE: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Pearson, Matthew R. via Tech-talk
Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Hu, Yong via Tech-talk
Prev: Re: Linux memory problems/questions Michael Davidsaver via Tech-talk
Next: Re: EPICS stopped Hu, Yong via Tech-talk
Prev: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Hu, Yong via Tech-talk
Next: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Heinz Junkes via Tech-talk
