Subject: Re: using autosave, iocInit hangs
From: Heinz Junkes via Tech-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Cc: Tech talk <[email protected]>
Date: Tue, 25 May 2021 21:33:05 +0200
I also have the reccaster running on the system.
It looks like the casterInit function leads to blocking.
I have the function sockpair_compat under suspicion.
However, I need to investigate this further.
Heinz
> On 23. May 2021, at 22:24, junkes via Tech-talk <[email protected]> wrote:
> I was using EPICS 7 with RTEMS 5 and have now also enabled autosave.
> Unfortunately in Main iocInit does not come back but hangs at the last
> InitHookAnnounce in iocRun
>    if (iocState == iocBuilt)
>        initHookAnnounce(initHookAtEnd);
>    errlogPrintf("iocRun: %s\n", iocState == iocBuilt ?
>        "All initialization complete" :
>        "IOC restarted");
>    iocState = iocRunning;
>    initHookAnnounce(initHookAfterIocRunning);
>    return 0;
> and no new iocsh(NULL) is started.
> int main(int argc,char *argv[])
>    if(argc>=2) {
>        iocsh(argv[1]);   <----- here it gets stuck
>        epicsThreadSleep(.2);
>    iocsh(NULL);
> # autosave setup
> dbLoadRecords("db/save_restoreStatus.db", "P=iocvmeIOC3:")
> ## autoSaveRestore setup
> save_restoreSet_Debug(0)
> # status-PV prefix, so save_restore can find its status PV's.
> save_restoreSet_status_prefix("iocvmeIOC3:")
> # ok to restore a save set that had missing values (no CA connection to PV)?
> # ok to save a file if some CA connections are bad?
> save_restoreSet_IncompleteSetsOk(1)
> #In the restore operation, a copy of the save file will be written.  The
> # file name can look like "auto_settings.sav.bu", and be overwritten every
> # reboot, or it can look like "auto_settings.sav_020306-083522" (this is what
> # is meant by a dated backup file) and every reboot will write a new copy.
> save_restoreSet_DatedBackupFiles(1)
> # specify where save files should go
> set_savefile_path("/Volumes/Epics/LogDir/log/as","/save")
> # specify where request files can be found
> set_requestfile_path("/Volumes/Epics/LogDir/log/as","/req")
> # Specify what save files should be restored when.
> # Up to eight files can be specified for each pass.
> set_pass0_restoreFile("iocvmeIOC3_0.sav")
> set_pass1_restoreFile("iocvmeIOC3_1.sav")
> # Number of sequenced backup files (e.g., 'auto_settings.sav0') to write
> save_restoreSet_NumSeqFiles(3)
> save_restoreSet_SeqPeriodInSeconds(600)
> # Time between failed .sav-file write and the retry.
> save_restoreSet_RetrySeconds(60)
> makeAutosaveFileFromDbInfo("/Volumes/Epics/LogDir/log/as/req/iocvmeIOC3_0.req", "autosaveFields_pass0")
> makeAutosaveFileFromDbInfo("/Volumes/Epics/LogDir/log/as/req/iocvmeIOC3_1.req", "autosaveFields_pass1")
> iocInit
> iocInit: Reached initHookAtIocBuild
> Starting iocInit
> iocInit: Reached initHookAtBeginning
> ## EPICS R7.0.4.2-DEV
> ## Rev. R7.0.4.1-274-g31ade32004709a9d47e8-dirty
> iocInit: Reached initHookAfterCallbackInit
> iocInit: Reached initHookAfterCaLinkInit
> iocInit: Reached initHookAfterInitDrvSup
> iocInit: Reached initHookAfterInitRecSup
> reboot_restore: entry for file 'iocvmeIOC3_0.sav'
> reboot_restore: Found filename 'iocvmeIOC3_0.sav' in restoreFileList.
> *** restoring from '/Volumes/Epics/LogDir/log/as/save/iocvmeIOC3_0.sav' at initHookState 6 (before record/device init) ***
> reboot_restore: done with file 'iocvmeIOC3_0.sav'
> iocInit: Reached initHookAfterInitDevSup
> 2021/05/23 20:07:03.501 sis0: Param Timestamp Clear can not be read
> reboot_restore: entry for file 'iocvmeIOC3_1.sav'
> reboot_restore: Found filename 'iocvmeIOC3_1.sav' in restoreFileList.
> *** restoring from '/Volumes/Epics/LogDir/log/as/save/iocvmeIOC3_1.sav' at initHookState 7 (after record/device init) ***
> reboot_restore: done with file 'iocvmeIOC3_1.sav'
> iocInit: Reached initHookAfterInitDatabase
> iocInit: Reached initHookAfterFinishDevSup
> iocInit: Reached initHookAfterScanInit
> iocInit: Reached initHookAfterInitialProcess
> iocInit: Reached initHookAfterCaServerInit
> iocInit: Reached initHookAfterIocBuilt
> iocInit: Reached initHookAtIocRun
> iocInit: Reached initHookAfterDatabaseRunning
> iocInit: Reached Not an initHookState
> iocInit: Reached initHookAfterCaServerRunning
> iocRun: All initialization complete
> no return ...
> Danke, Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: using autosave, iocInit hangs Michael Davidsaver via Tech-talk
using autosave, iocInit hangs junkes via Tech-talk
Prev: Re: "Starter Kit" for learning EPICS? J. Lewis Muir via Tech-talk
Next: Re: Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Prev: using autosave, iocInit hangs junkes via Tech-talk
Next: Re: using autosave, iocInit hangs Michael Davidsaver via Tech-talk
