Subject: New releases of areaDetector modules (ADCore R3-11 and others)
Date: Wed, 26 May 2021 21:01:02 +0000
Folks,
There are new releases of a number of areaDetector modules.  These are the major items from each of the RELEASE.md files.
* ADSupport R1-10
  * Changed the support for reading MJPEG streams in GraphicsMagickSrc and xml2Src.
* ADCore R3-11
  * New plugin NDPluginBadPixel.
* ADGenICam R1-7-1
  * Fixed memory leak.
* ADAravis R2-2-1
  * Added continuous integration via Github Actions.  Thanks to Michael Davidsaver for this.
  * Improve error reporting by fetching the underlying error from aravis.
* ADSpinnaker R3-2
  * Updated Spinnaker version from 2.0.0.147 to 2.4.0.147.
* ADURL R2-3
  * Converted documentation to ReST, include in documentation on github.io.
  * Added autoconverted OPI files for css/BOY, css/Phoebus, edm, and caQtDM.
  * Fix to release the lock at least briefly between each image, otherwise EPICS puts don't get processed.
* ADViewers R1-7
  * Many enhancements to the Python PY_NTNDA_Viewer.
  * Updated to the latest versions of the EPICS Java libraries.
The home page is here:
https://github.com/areaDetector
The top-level documentation is here:
https://areadetector.github.io/master/index.html
Installation instructions are here:
https://areadetector.github.io/master/install_guide.html
areaDetector release notes are here:
https://github.com/areaDetector/areaDetector/blob/master/RELEASE.md
ADCore release notes are here:
https://github.com/areaDetector/ADCore/blob/master/RELEASE.md
Prev: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Prev: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Important Notice Regarding EPICS Collaboration Meeting Spring 2021 Glen Wright via Tech-talk
