Thanks Torsten, your suggestion worked like a charm!
/Markus
2021-05-27 18:59 skrev Torsten Bögershausen:
Hej Markus,
If I set this line in my shell-script:
export EPICS_PVAS_INTF_ADDR_LIST=127.0.0.1
I can start the IOC.
It will give you a warning:
No server broadcast addresses found or specified - empty address list!
which is nice
/Torsten
On 27 maj 2021, at 14:44, [email protected] wrote:
Hej Torsten,
Hope you are doing well!
Interesting. Since I use PyEpics/PyQt for the GUI that would probably
be a solution for me. However, I do use e3, but I suspect that
updating this make-file would be feasible herein also?
For future reference, if pvaccess was to be used on an offgrid device,
could a possible solution be to create a virtual dummy interface on
the RPi?
Cheers from Skåne,
Markus
2021-05-27 08:41 skrev Torsten Bögershausen:
Hej Markus,
as far as I know:
The "IOC not probably working when we don't have any physical network
interfaces" is only there for pvacess.
pvaccess uses a different way than channel access
(to detect interfaces which the ca/pv binds to).
Looking from the EPICS community point of view, it seems as if this
"networkless IOC" is rarely used.
In your case it may help to disable the pvaccess completely.
I have something like this in my Makefile:
ifdef BASE_7_0
ethercatmc_DBD += PVAServerRegister.dbd
ethercatmc_DBD += PVACommonRegister.dbd
ethercatmc_DBD += softIocPVA.dbd
ethercatmc_DBD += registerChannelProviderLocal.dbd
endif
HTH, greetings to Lund
/Torsten
On 5/27/21 12:04 AM, Markus Kristensson via Tech-talk wrote:
Hi again,
I've investigated the problem further. It turns out that I was too
quick in judging that the IOC was starting up more or less correctly
even when the ethernet cable was not plugged in. The reason for that
conclusion was two-fold: 1. I ran the RPi in headless mode without
any monitor connected. 2. The RPi did respond to change in some
hardware, namely me changing a physical switch between two states.
The response of changing the switch was seen in the
opening/closening of a relay. As already stated, the response was
very slow (sometimes around 10 s). What bugged me was that the same
relay card did not open when a number of other DI:s received signal.
With a monitor connected I now realise that the IOC is actually NOT
starting correctly when the ethernet cable is unplugged. The error
is a BaseException with "No (specified) network interface(s)
available". Interestingly, the plc (I run the ecmc-module) which
handels the logic starts up briefly before the IOC startup is
terminated. This gives enough time to read the input from the switch
and to open up the relay, but not enough time for the other inputs
to respond because of the logic using hysteresis (this is a solution
for dealing with 14 cooling rooms and 2 cooling machines etc...).
The slow responding time of the switch (max around 10 s) should then
basically be related to the restart time of the IOC which I've
configured using systemd to 10 s.
So, some things better understood, but my basic problem still
remains. Do you have any suggestions of how I can resolve the
problem of starting an IOC without it being connected to any
network? I suspect I need to modify the startup script of the IOC,
e.g. specifying EPICS_CA_ADDR_LIST to localhost. So far I have not
been successful with such modifications.
Cheers,
Markus
2021-05-26 20:31 skrev Markus Kristensson via Tech-talk:
I have configured a Raspberry Pi 3 Model b+ to autostart and launch
an
IOC. The startup works fine if the RasPi is connected via ethernet
to
another computer. If the lan is not connected at startup, the IOC
is
basically unusable, responding to certain inputs, but extremely
slow.
If the ethernet cable is plugged back in, the responsiveness of the
IOC is back to normal.
The RasPi will normally be connected to the other computer, but it
is
not necessarily so. I only need to control and access the IOC on
the
RasPi locally (i.e. on the Raspberry Pi itself). Do you have any
suggestions how to proceed?
Cheers,
Markus Kristensson
- IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
- Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
- Re: IOC unusable if no ethernet interface at startup Torsten Bögershausen via Tech-talk
RE: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Epics MODbus driver, can this be run as a MODbus Slave? Heinz Junkes via Tech-talk
<2021>
2025
2026
New releases of areaDetector modules (ADCore R3-11 and others) Mark Rivers via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
