Hi again,
I've investigated the problem further. It turns out that I was too quick
in judging that the IOC was starting up more or less correctly even when
the ethernet cable was not plugged in. The reason for that conclusion
was two-fold: 1. I ran the RPi in headless mode without any monitor
connected. 2. The RPi did respond to change in some hardware, namely me
changing a physical switch between two states. The response of changing
the switch was seen in the opening/closening of a relay. As already
stated, the response was very slow (sometimes around 10 s). What bugged
me was that the same relay card did not open when a number of other DI:s
received signal.
With a monitor connected I now realise that the IOC is actually NOT
starting correctly when the ethernet cable is unplugged. The error is a
BaseException with "No (specified) network interface(s) available".
Interestingly, the plc (I run the ecmc-module) which handels the logic
starts up briefly before the IOC startup is terminated. This gives
enough time to read the input from the switch and to open up the relay,
but not enough time for the other inputs to respond because of the logic
using hysteresis (this is a solution for dealing with 14 cooling rooms
and 2 cooling machines etc...). The slow responding time of the switch
(max around 10 s) should then basically be related to the restart time
of the IOC which I've configured using systemd to 10 s.
So, some things better understood, but my basic problem still remains.
Do you have any suggestions of how I can resolve the problem of starting
an IOC without it being connected to any network? I suspect I need to
modify the startup script of the IOC, e.g. specifying EPICS_CA_ADDR_LIST
to localhost. So far I have not been successful with such modifications.
Cheers,
Markus
2021-05-26 20:31 skrev Markus Kristensson via Tech-talk:
I have configured a Raspberry Pi 3 Model b+ to autostart and launch an
IOC. The startup works fine if the RasPi is connected via ethernet to
another computer. If the lan is not connected at startup, the IOC is
basically unusable, responding to certain inputs, but extremely slow.
If the ethernet cable is plugged back in, the responsiveness of the
IOC is back to normal.
The RasPi will normally be connected to the other computer, but it is
not necessarily so. I only need to control and access the IOC on the
RasPi locally (i.e. on the Raspberry Pi itself). Do you have any
suggestions how to proceed?
Cheers,
Markus Kristensson
- Re: IOC unusable if no ethernet interface at startup Torsten Bögershausen via Tech-talk
- IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
New releases of areaDetector modules (ADCore R3-11 and others) Mark Rivers via Tech-talk
Important Notice Regarding EPICS Collaboration Meeting Spring 2021 Glen Wright via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
