Yeah, I should have mentioned 3.14
On 6/10/21 12:29 PM, Ralph Lange wrote:
On Thu, 10 Jun 2021 at 12:25,
Till Straumann via Tech-talk < [email protected]>
wrote:
Unfortunately,
I believe what you want to do (and which seems
reasonable) is not possible.
You can work-around (if performance is not critical), e.g.,
by writing
a calcout device support
module that
1. fetches a copy of the entire waveform
2. modifies the target element
3. writes the modified waveform back to the waveform record
- Till
On 6/10/21 12:00 PM, Florian Feldbauer via Tech-talk wrote:
> Hey all,
> I have a question regarding waveform records. So far I
never really
> worked with waveform or any other array-type record.
> The Situation is:
> - Our DAQ collects the data coming from our Pixel sensor.
> - Every 10s an IOC reads the stored data and fills a
waveform record
> with the hits (index of array = pixel, value = number of
hits in the run)
> - I use an image widget in Phoebus to display the hit map
of the pixel
> sensor
> Now, for testing the sensors after bonding, we can
perform charge
> injections to individual pixels. We can also mask
individual pixels if
> they are too noisy.
> As we need to always send the information for all pixels
to the
> sensor, I thought about using a second waveform record
holding the per
> pixel configuration.
> Using the cursor X/Y PVs from the image widget in phoebus
I could
> select a pixel I want to inject a charge for testing (or
I want to
> mask b/c it's noisy) and get calculate the index within
the waveform
> record from these two PV's using a CALC record.
> So now my actual question: Let's say I want to mask pixel
42, is it
> possible to just write to val[41] from my config waveform
record from
> a CALC(OUT) record without touching the other values of
the array?
> Cheers,
> Florian
- Writing to Waveform from CALC Florian Feldbauer via Tech-talk
- Re: Writing to Waveform from CALC Till Straumann via Tech-talk
- Re: Writing to Waveform from CALC Ralph Lange via Tech-talk
Re: Writing to Waveform from CALC Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
