Hi Mark,
Thank you. The problem is reduced. I still can't connect to
power supply. Can it be caused by virtual network (bridged
network)? But I can get ping including transmitted and received
packages. I think this cannot origin of this problem. Port
numbers are written in power supply's manual that 8003 for TCP
and 8005 for UDP. There are outputs of st.cmd file and ping
command.
~/EPICS/IOCs/TDK/iocBoot/iocTDKtest$ ./st.cmd
#!../../bin/linux-x86_64/TDKtest
## You may have to change TDKtest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocTDKtest")
epicsEnvSet("TOP","/home/osiloskop/EPICS/IOCs/TDK")
epicsEnvSet("STREAM","/home/osiloskop/EPICS/support/StreamDevice")
epicsEnvSet "STREAM_PROTOCOL_PATH"
"/home/osiloskop/EPICS/IOCs/TDK/db"
# Allow PV name prefixes and serial port name to be set
from the environment
epicsEnvSet "P" "tdk_lambda"
epicsEnvSet "R" "Test"
epicsEnvSet "TTY" "10.97.4.4:8003"
cd "/home/osiloskop/EPICS/IOCs/TDK"
dbLoadDatabase "dbd/TDKtest.dbd"
TDKtest_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority
noAutoconnect noProcessEos
drvAsynIPPortConfigure("L0","10.97.4.4:8003",0,0,0)
2021/06/22 16:12:24.130 L0 -1 autoConnect could not
connect: Can't connect to 10.97.4.4:8003: Connection refused
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
## Load record instances
#dbLoadRecords("db/xxx.db","user=osiloskop")
dbLoadRecords("db/devTDK.db","P=tdk_lambda,R=Test,PORT=L0,A=0")
cd "/home/osiloskop/EPICS/IOCs/TDK/iocBoot/iocTDKtest"
iocInit
Starting iocInit
## EPICS R3.15.8.1-DEV
## EPICS Base built Jun 22 2021
2021/06/22 16:12:25.136556 _main_ tdk_lambdaTestIDN
lockRequest: port L0 not connected
2021/06/22 16:12:25.138558 _main_ tdk_lambdaTestIDNwf
## Start any sequence programs
#seq sncxxx,"user=osiloskop"
$ ping 10.97.4.4
PING 10.97.4.4 (10.97.4.4) 56(84) bytes of data.
64 bytes from 10.97.4.4: icmp_seq=1 ttl=63 time=0.549 ms
64 bytes from 10.97.4.4: icmp_seq=2 ttl=63 time=0.935 ms
64 bytes from 10.97.4.4: icmp_seq=3 ttl=63 time=0.949 ms
64 bytes from 10.97.4.4: icmp_seq=4 ttl=63 time=0.307 ms
64 bytes from 10.97.4.4: icmp_seq=5 ttl=63 time=0.778 ms
64 bytes from 10.97.4.4: icmp_seq=6 ttl=63 time=0.767 ms
64 bytes from 10.97.4.4: icmp_seq=7 ttl=63 time=0.812 ms
64 bytes from 10.97.4.4: icmp_seq=8 ttl=63 time=0.954 ms
^C
--- 10.97.4.4 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time
86ms
rtt min/avg/max/mdev = 0.307/0.756/0.954/0.212 ms
Hasan.
On 22.06.2021 15:56, Mark Rivers
wrote:
Hi Hasan,
Your problem is this first error:
st.cmd line 22: Command drvAsynIPPortConfigure not found.
You can see from the "help" output that indeed that command is not defined. That means your TDKtest application was not built with support for asyn and drvAsynIPPort. You need to change the Makefile for building TDKtest to have lines like this:
TDKtest_DBD += asyn.dbd
TDKtest_DBD += drvAsynIPPort.dbd
For some reason you do have drvAsynSerialPort.dbd in your application, but not asyn.dbd or drvAsynIPPort.dbd.
From: Tech-talk <[email protected]> on behalf of Hasan SANSAR via Tech-talk <[email protected]>
Sent: Tuesday, June 22, 2021 7:45 AM
To: [email protected]
Subject: StreamDevice support problem: Cannot find a bus named 'L0' for...
I am a new member of EPICS platform. I installed EPICS R3.15.8.1-DEV from LaunchPad that given 'git' command on epics-contols.org and also StreamDevice and asyn from GitHub, and so I applied instructions on docs.epics-controls.org and there is no problem for installation and for example of creation IOC.
My environment is Debian GNU/Linux 10 Buster server installation without desktop GUI on Virtual Box. I'm trying to connect TDK-Lambda Z36-12-LAN Power Supply through ethernet connection with ethernet cable. There is no problem, because I can get ping from power supply's IP on Debian Virtualbox.
All in all, I start to follow Eric Norum's tutorial about device support (Or else, is it deprecated?):
https://epics.anl.gov/modules/soft/asyn/R4-24/HowToDoSerial/HowToDoSerial_StreamDevice.html
And I get error end of third step below. (I added several informations below of the error message.) I think stream does not detect asyn, but why?
< envPaths
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/osiloskop/EPICS/IOCs/TDK/db"
# Allow PV name prefixes and serial port name to be set from the environment
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority noAutoconnect noProcessEos
st.cmd line 23: Command asynSetTraceIOMask not found.
st.cmd line 24: Command asynSetTraceMask not found.
iocInit
Starting iocInit
2021/06/22 14:22:33.738076 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestIDN'
2021/06/22 14:22:33.738776 _main_ tdk_lambdaTestIDN: Can't attach to bus L0 0
2021/06/22 14:22:33.739342 _main_ tdk_lambdaTestIDN: Record initialization failed
2021/06/22 14:22:33.739909 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestIDNwf'
2021/06/22 14:22:33.740447 _main_ tdk_lambdaTestIDNwf: Can't attach to bus L0 0
2021/06/22 14:22:33.740981 _main_ tdk_lambdaTestIDNwf: Record initialization failed
2021/06/22 14:22:33.741510 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetSTB'
2021/06/22 14:22:33.742124 _main_ tdk_lambdaTestGetSTB: Can't attach to bus L0 0
2021/06/22 14:22:33.742664 _main_ tdk_lambdaTestGetSTB: Record initialization failed
2021/06/22 14:22:33.743210 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetESR'
2021/06/22 14:22:33.743758 _main_ tdk_lambdaTestGetESR: Can't attach to bus L0 0
2021/06/22 14:22:33.744297 _main_ tdk_lambdaTestGetESR: Record initialization failed
2021/06/22 14:22:33.744844 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetESE'
2021/06/22 14:22:33.745381 _main_ tdk_lambdaTestGetESE: Can't attach to bus L0 0
2021/06/22 14:22:33.746009 _main_ tdk_lambdaTestGetESE: Record initialization failed
2021/06/22 14:22:33.746585 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetSRE'
2021/06/22 14:22:33.747116 _main_ tdk_lambdaTestGetSRE: Can't attach to bus L0 0
2021/06/22 14:22:33.747660 _main_ tdk_lambdaTestGetSRE: Record initialization failed
2021/06/22 14:22:33.748211 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetOPC'
2021/06/22 14:22:33.748760 _main_ tdk_lambdaTestGetOPC: Can't attach to bus L0 0
2021/06/22 14:22:33.749291 _main_ tdk_lambdaTestGetOPC: Record initialization failed
2021/06/22 14:22:33.749879 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestSetESE'
2021/06/22 14:22:33.750409 _main_ tdk_lambdaTestSetESE: Can't attach to bus L0 0
2021/06/22 14:22:33.750946 _main_ tdk_lambdaTestSetESE: Record initialization failed
2021/06/22 14:22:33.751492 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestSetSRE'
2021/06/22 14:22:33.752026 _main_ tdk_lambdaTestSetSRE: Can't attach to bus L0 0
2021/06/22 14:22:33.752555 _main_ tdk_lambdaTestSetSRE: Record initialization failed
2021/06/22 14:22:33.753122 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestRST'
2021/06/22 14:22:33.753600 _main_ tdk_lambdaTestRST: Can't attach to bus L0 0
2021/06/22 14:22:33.754200 _main_ tdk_lambdaTestRST: Record initialization failed
2021/06/22 14:22:33.754888 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestCLS'
2021/06/22 14:22:33.755377 _main_ tdk_lambdaTestCLS: Can't attach to bus L0 0
2021/06/22 14:22:33.755955 _main_ tdk_lambdaTestCLS: Record initialization failed
epics> help
Type 'help <command>' to see the arguments of <command>.
# ClockTime_Report ClockTime_Shutdown
TDKtest_registerRecordDeviceDriver asDumpHash asInit
asSetFilename asSetSubstitutions ascar asdbdump
asphag aspmem asprules aspuag astac
callbackParallelThreads callbackSetQueueSize casr
cd coreRelease date dbDumpBreaktable
dbDumpDevice dbDumpDriver dbDumpField dbDumpFunction dbDumpMenu
dbDumpPath dbDumpRecord dbDumpRecordType
dbDumpRegistrar dbDumpVariable dbLoadDatabase dbLoadRecords dbLoadTemplate
dbLockShowLocked dbNotifyDump dbPutAttribute dbPvdDump
dbPvdTableSize dbReportDeviceConfig dbStateClear dbStateCreate
dbStateSet dbStateShow dbStateShowAll dba dbap
dbb dbc dbcar dbd dbel
dbgf dbgrep dbhcr dbior dbl
dbla dblsr dbnr dbp dbpf
dbpr dbs dbsr dbstat dbtgf
dbtpf dbtpn dbtr drvAsynSerialPortConfigure
echo eltc epicsEnvSet epicsEnvShow epicsEnvUnset
epicsMutexShowAll epicsParamShow epicsPrtEnvParams
epicsThreadResume epicsThreadShow epicsThreadShowAll
epicsThreadSleep errlog errlogInit errlogInit2
exit generalTimeReport gft help
installLastResortEventProvider iocBuild iocInit iocLogInit
iocLogPrefix iocLogShow iocPause iocRun iocshCmd
iocshLoad iocshRun pft postEvent pwd
registryDeviceSupportFind registryDriverSupportFind registryDump
registryFunctionFind registryRecordTypeFind
scanOnceSetQueueSize scanpel scanpiol scanppl
setIocLogDisable streamReinit streamReload
streamReportRecord streamSetLogfile taskwdShow
tpn var
epics> drvAsynSerialPortConfigure
Port name missing.
epics> drvAsyn
Command drvAsyn not found.
epics> asynReport(10,SERIALPORT)
Command asynReport not found.
epics> dbior "stream"
Driver: stream
StreamDevice 2.8.19-dirty 2021-04-09 17:41:57 +0200
commit: 377d511c670193c5d49493ebcb5e7385fb34440a
(C) 1999 Dirk Zimoch ([email protected]<mailto:[email protected]>)
Use interest level 100 for license information
registered bus interfaces:
DebugInterface
DummyInterface
AsynDriverInterface
~/EPICS/IOCs/TDK/dbd$ grep -i stream TDKtest.dbd
device(stringin, INST_IO, devstringinStream, "stream")
device(stringout, INST_IO, devstringoutStream, "stream")
device(aao, INST_IO, devaaoStream, "stream")
device(mbbi, INST_IO, devmbbiStream, "stream")
device(bi, INST_IO, devbiStream, "stream")
device(waveform, INST_IO, devwaveformStream, "stream")
device(ao, INST_IO, devaoStream, "stream")
device(lso, INST_IO, devlsoStream, "stream")
device(mbbiDirect, INST_IO, devmbbiDirectStream, "stream")
device(longin, INST_IO, devlonginStream, "stream")
device(ai, INST_IO, devaiStream, "stream")
device(aai, INST_IO, devaaiStream, "stream")
device(longout, INST_IO, devlongoutStream, "stream")
device(mbbo, INST_IO, devmbboStream, "stream")
device(bo, INST_IO, devboStream, "stream")
device(mbboDirect, INST_IO, devmbboDirectStream, "stream")
device(lsi, INST_IO, devlsiStream, "stream")
device(calcout, INST_IO, devcalcoutStream, "stream")
driver(stream)
registrar(streamRegistrar)
variable(streamDebug, int)
variable(streamDebugColored, int)
variable(streamError, int)
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 08:00:27:48:94:10 brd ff:ff:ff:ff:ff:ff
inet 10.0.2.15/24 brd 10.0.2.255 scope global dynamic enp0s3
valid_lft 67195sec preferred_lft 67195sec
inet6 fe80::a00:27ff:fe48:9410/64 scope link
3: enp0s8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 70:54:d2:db:d2:d4 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7254:d2ff:fedb:d2d4/64 scope link
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:ce:4a:e5:26 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
$tail -5 ~/.bashrc
export EPICS_BASE=${HOME}/EPICS/epics-base
export EPICS_HOST_ARCH=$(${EPICS_BASE}/startup/EpicsHostArch)
export PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
export ASYN=${HOME}/EPICS/support/asyn
export EPICS_DISPLAY_PATH=${ASYN}/opi/medm
~/EPICS/IOCs/TDK/dbd$ less ../../../support/asyn/configure/RELEASE
#RELEASE Location of external products
SUPPORT=/home/osiloskop/EPICS/support
# IPAC is only necessary if support for Greensprings IP488 is required
# IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-15
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-2-5
## For sCalcout support in asynOctet - applications include asynCalc.dbd
#CALC=$(SUPPORT)/calc-3-7-3
# If CALC was built with SSCAN support then SSCAN must be defined for testEpicsApp
#SSCAN=$(SUPPORT)/sscan-2-11-3
# EPICS_BASE 3.14.6 or later is required
EPICS_BASE=/home/osiloskop/EPICS/epics-base
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
less ../../../support/StreamDevice/configure/RELEASE
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=${HOME}/EPICS/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/asyn
#PCRE=$(SUPPORT)/pcre-7-2
# EPICS_BASE usually appears last so other apps can override stuff:
# These lines allow developers to override these RELEASE settings
# without having to modify this file directly.
Thank you for your help in the future.
Best regards.
Hasan Sansar
Hasan Sansar
- Re: [EXTERNAL] StreamDevice support problem: Cannot find a bus named 'L0' for... Hartman, Steven via Tech-talk
- StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
- Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
