Subject: Re: [EXTERNAL] StreamDevice support problem: Cannot find a bus named 'L0' for...
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: Hasan SANSAR <[email protected]>
Date: Tue, 22 Jun 2021 13:40:18 +0000
On Jun 22, 2021, at 9:28 AM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
drvAsynIPPortConfigure("L0","10.97.4.4:8003",0,0,0)
2021/06/22 16:12:24.130 L0 -1 autoConnect could not connect: Can't connect to 10.97.4.4:8003: Connection refused
“Connection refused” indicates that you are not able to reach TCP port 8003 at 10.97.4.4. Verify that you are using the correct address and port number and the device is online and listening on that port. Also check if there are any firewalls that may be blocking the connection.
You can test from the same host that is running the IOC with
  telnet 10.97.4.4 8003
Steven Hartman
[email protected]
StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Mark Rivers via Tech-talk
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Prev: Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Next: Timestamp not updating with pvput and PvaPy KRL Baker - STFC UKRI via Tech-talk
