>Dear all,
>I start an soft IOC server in local computer and intend to
monitor its running status by using alive record.
>The IP address of the soft IOC is 127.0.0.1, then for alive
record I set:
>epicsEnvSet("ALIVE_SERVER","127.0.0.1") in st.cmd and I use
its default example db as a test, then I start the alive record.
>My problem is when "dbpr aliveEx:alive", the SEVR is always
INVALID, I have no idea if I miss something and which program
should I need to install to make the alive record work.
>Thank you very much in advance and an example step for starting alive record is
appreciated.
The alive record by itself isn't very useful. You need a remote server that listens for the heartbeat UDP messages generated by the alive record, which is what is specified by ALIVE_SERVER above. When I wrote the record, I assumed people would want to write their own remote server code for interacting with alive record from IOCs, although I'm not sure if that happened much. I released the server code as used by the BCDA group of the Advanced Photon Source earlier this year, which I wrote when I was in that group. You can find information on it and how to use it at https://epics-alive-server.github.io/ . About SEVR, I unfortunately ignored alarms when I wrote the record, as alarms didn't make sense for how it worked. I will look into fixing those alarm fields. So you can ignore SEVR being INVALID, as it doesn't signify a problem. Dohn Arms
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
