Subject: Re: Best practices for booting IOC at Linux startup?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Feister, Scott" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 21 Jul 2021 23:23:41 +0000
Hi Scott,
In case it wasn’t obvious: Starting IOCs inside tmux or procServ (or GNU Screen as we use at APS) is recommended to allow you to connect to the IOC console and run diagnostic commands using the IOC shell, in case you need to debug issues with the IOC or its client connections. It is possible to create and run IOCs without a shell, but it provides many commands which can give you information about what it’s doing which you can’t otherwise access remotely.
The procServ package is probably the simplest approach, but it doesn’t give you the ability to scroll back and look at messages that were shown on the IOC console before you connected, like tmux or Screen can. You can have procServ log the console output to a file though, or if you start it using systemd it could send everything to the systemd journal.
Recent versions of procServ come with support scripts for use with systemd; post here if you have questions about them.
HTH,
- Andrew
On Jul 21, 2021, at 5:29 PM, Feister, Scott via Tech-talk <[email protected]> wrote:
Hi Lewis and Ernesto,
Thank you both for the advice! I appreciate your support and will try out both approaches.
Best,
Scott
-----Original Message-----
Sent: Tuesday, July 20, 2021 7:24 PM
To: Feister, Scott <[email protected]>
Cc: [email protected]
CAUTION: This email originated from outside of CSUCI. Do not click links or open attachments unless you validate the sender and know the content is safe. Contact ITS if you have any concerns
On 07/20, Feister, Scott via Tech-talk wrote:
Can anyone share some best practices on having an IOC boot whenever Linux boots? I'm trying to make it as easy as possible to reboot the instrument, by simply power cycling. The hardware is a Raspberry Pi whose sole purpose is to boot and run its IOC every time it powers on. Thanks!
I run my soft IOCs in tmux started as a service.
Lewis
Complexity comes for free, simplicity you have to work for.
Re: Best practices for booting IOC at Linux startup? Hu, Yong via Tech-talk
Best practices for booting IOC at Linux startup? Feister, Scott via Tech-talk
Re: Best practices for booting IOC at Linux startup? J. Lewis Muir via Tech-talk
RE: Best practices for booting IOC at Linux startup? Feister, Scott via Tech-talk
Prev: RE: Best practices for booting IOC at Linux startup? Feister, Scott via Tech-talk
Next: Re: Best practices for booting IOC at Linux startup? Hu, Yong via Tech-talk
