I have encountered a problem with pyepics, the most recent version on rhel7.
The trouble is: I have many PV on a local IOC, but also want to access another PV reachable
via a gateway on port 5062.
I set an appropriate EPICS_CA_ADDR_LIST like: export EPICS_CA_ADDR_LIST="hipa-cagw:5062:localhost“,
and this works to my satisfaction with the standard caget from EPICS base.
If I start python from the same terminal == same environment, load pyepics, and try to use
caget() I cannot access any PV’s at all. I have not found any reference to EPICS_CA_ADDR_LIST in the
pyepics docs. Is this a limitation or a bug? Or am I missing something?
We eventually worked around the problem by installing a calc record pointing to the PV accessible through
the gateway in our IOC and this works.
Best Regards,
Mark Koennecke
- Re: pyepcis does not seem to honor EPICS_CA_ADDR_LIST Mark Rivers via Tech-talk
Re: Re: Re: detector state error and writing status error for marCCD 秦文明 via Tech-talk
<2021>
2025
2026
CA/PVA Wireshark (Lua dissectors) on RedHat 8 Ralph Lange via Tech-talk
<2021>
2025
2026
