1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: caget freezes the bash script
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 22 Jul 2021 19:11:20 +0200
On Thu, 22 Jul 2021 at 15:05, Vodopivec, Klemen via Tech-talk <[email protected]> wrote:
Interestingly, adding a dummy redundant pvget beforehand fixes the issue for the duration of the script:
pvget -p ca -w 0.5 -t ${BL}:CS:TL:RemExp:En 2>/dev/null
remexp_enabled=$(pvget -p ca -w 0.5 -t ${BL}:CS:TL:RemExp:En 2>/dev/null)
However, when similar dummy pvget is run before executing the script, the issue gets resolves completely.
Weird.
The easy explanation would be that pvget (or any library it uses) is changing the environment in a way that avoids the failure later on. Sounds unlikely, though.
Comparing environment dumps could rule that out.
~Ralph
caget freezes the bash script Vodopivec, Klemen via Tech-talk
Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Prev: Re: [EXTERNAL] Re: caget freezes the bash script Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] caget freezes the bash script Vodopivec, Klemen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
