1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] caget freezes the bash script
From: "Vodopivec, Klemen via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "J. Lewis Muir" <[email protected]>
Date: Thu, 22 Jul 2021 19:12:41 +0000
> On Jul 22, 2021, at 12:22 PM, Kasemir, Kay via Tech-talk <[email protected]> wrote:
> >> > Which is it, caget or pvget?  They're two separate programs.
> >> The script is using `pvget -p ca ...`, so in the end it's using the CA client library, same as `caget ...`
> >I understand that in theory it should be the same, but when trying to track down an issue, it's not good to assume such things.
> Indeed, and the EPICS version might make a difference.
You’re absolutely right, little details matter in trying to troubleshoot. But I intentionally didn’t want to blast with massive amount of information that would scare people away.
> I read
>   "pvget replaced caget, giving us two implementations that behave the same."
> as both "caget" and "pvget -p ca" were used with the same result.
Correct, both caget and pvget were tried with the same effect. Both caget and pvget are compiled from the same 3.14.12.6 distribution, pvget is from PVAccess library version 4.5.
> Maybe one can attach gdb to the hung caget/pvget process and see why it's stuck and not exiting.
Interestingly, after the bash script freezes, pvget doesn’t show in the list of processes any more. But I know it ran based on the wireshark output. Which would indicate problem in bash script somehow but the line after the one showed simply doesn’t execute. So it’s like pvget or caget leave the stdout descriptor open and bash script can’t continue. I say this because the following modified line works fine
remexp_enabled=$(pvget -p ca -w 0.5 -t ${BL}:CS:TL:RemExp:En | echo enable 2>/dev/null)
But this one hangs similar to the original line (expected PV value is 'enabled' or 'disabled')
remexp_enabled=$(pvget -p ca -w 0.5 -t ${BL}:CS:TL:RemExp:En | grep enabled 2>/dev/null)
The difference is that echo doesn’t care about the stdin and executes immediately, while grep has to wait for closed stdin before it can exit. But that’s just a wild guess.
— Klemen
Re: [EXTERNAL] caget freezes the bash script Zimmermann, David Daniel via Tech-talk
Re: [EXTERNAL] caget freezes the bash script Johnson, Andrew N. via Tech-talk
caget freezes the bash script Vodopivec, Klemen via Tech-talk
Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Prev: Re: [EXTERNAL] Re: caget freezes the bash script Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] caget freezes the bash script Zimmermann, David Daniel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
