Subject: Re: [EXTERNAL] Re: caget freezes the bash script
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 22 Jul 2021 16:22:17 +0000
>> > Which is it, caget or pvget?  They're two separate programs.
>> The script is using `pvget -p ca ...`, so in the end it's using the CA client library, same as `caget ...`
>I understand that in theory it should be the same, but when trying to track down an issue, it's not good to assume such things.
Indeed, and the EPICS version might make a difference.
I read
  "pvget replaced caget, giving us two implementations that behave the same."
as both "caget" and "pvget -p ca" were used with the same result.
Might point to a problem in the CA client lib as the common denominator.
Maybe one can attach gdb to the hung caget/pvget process and see why it's stuck and not exiting.
-Kay
Re: [EXTERNAL] Re: caget freezes the bash script Ralph Lange via Tech-talk
Re: [EXTERNAL] caget freezes the bash script Vodopivec, Klemen via Tech-talk
Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Prev: RE: Best practices for booting IOC at Linux startup? Feister, Scott via Tech-talk
Next: Re: [EXTERNAL] Re: caget freezes the bash script Ralph Lange via Tech-talk
Prev: Re: [EXTERNAL] Re: caget freezes the bash script J. Lewis Muir via Tech-talk
