Subject: |
Re: Channel Access Timeouts - ca(get|put) CA Priority |
"Johnson, Andrew N. via Tech-talk" <[email protected]> |
To: |
"Yendell, Gary (DLSLtd,RAL,LSCI)" <[email protected]> |
Cc: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 23 Jul 2021 16:02:08 +0000 |
Hi Gary,
On Jul 23, 2021, at 9:51 AM, Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk < [email protected]> wrote:
We are having very occasional issues with CA timeouts (with a timeout of 3 seconds) from our control software (GDA). I think it is because the IOC sometimes doesn't respond when it is overwhelmed
with requests and when we have multiple instances of EDM screens open it can produce a lot of requests. These timeouts can cause scans to fail, so responsiveness for the EDM screens is much less important. If we add an appropriate value for the CA Priority
option to ca(get|put) in control software requests, would that make the IOC respond to it in preference to other clients and stop the timeout errors? Or am I misunderstanding what this option does?
The priority of a CA connection controls the priority of the EPICS threads in the IOC that are responsible for sending and receiving the CA messages. Whether and how the EPICS thread priority maps to that of the underlying OS depends on what OS the IOC
is running on.
For IOCs running on Linux the EPICS thread priority only has an effect if the IOC has enough privilege to use the real-time scheduler (regular users generally don’t have this enabled). See this
tech-talk message for a description and this how-to for detailed instructions. You might not even need to set the priorities of your
CA connections to fix this though, just enabling the scheduler may be enough since the IOC thread that responds to name searches runs at a lower priority than the CA threads (which are lower again than the IOC’s threads that run the process database).
The other thing you might want to do is look at the CA search traffic on your subnet and see if it’s worth cleaning up any clients that are searching for PV names that don’t exist. If you don’t keep an eye on old GUI screens and other clients these dead
searches can severely load down your IOCs. There are a couple of older tools I know of which can help to identify those PV names (caSnooper is probably best known), but the community might have others that I don’t know about.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
- Re: Channel Access Timeouts - ca(get|put) CA Priority Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
- Channel Access Timeouts - ca(get|put) CA Priority Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Phoebus Archive xml config file: Automate generation. Kuldeep Joshi via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
