Subject: Weird channel access problem within Python softioc process
From: Paul Richards via Tech-talk <[email protected]>
Date: Wed, 11 Aug 2021 00:05:59 +0000
All,
At Keck, we have been using the EPICS Python softioc with great success.  The recent 3.1 release has made it even more popular and easier to use.
That said, I have found a very odd behavior that I can replicate, relating to the consumption of keywords inside the same process that runs the softioc.  Sometimes it makes sense to do it this way, instead of finding a reference to the channel in the IOC and manipulating that.
A simplified example of the problem:
  1. Import the pyepics and softioc libraries.
  2. Start a softioc with a channel (call it ‘prefix:long’ in my example).
  3. Start a thread that periodically updates the channel with a new value.
  4. Start another thread that tries to access this channel, either with epics.PV() or epics.caget().
  5. Channel access in thread 2 always times out, forever.
Today I found a “solution” to this that does not make sense: if I start the softioc (the call to softioc.iotInit()) in the first thread, and not in the main process, everything works as expected.
Our engineers are unable to explain this behavior.  I hope there’s someone here on the list that might know why!
Example code that demonstrates the failure:
import os
import time
import threading
os.environ['EPICS_CA_SERVER_PORT'] = '5100'
os.environ['EPICS_CA_ADDR_LIST'] = 'localhost:5100'
os.environ['EPICS_CA_AUTO_ADDR_LIST'] = 'NO'
try:
    import epicscorelibs.path.pyepics
except ImportError:
    pass
import epics
from softioc import softioc, builder
# Create a long record for this demo
long = builder.longOut('prefix:long', initial_value=1)
builder.LoadDatabase()
softioc.iocInit()
def thread1():
    while True:
        val = long.get()
        long.set(val + 1)
        print(f'thread1: {val}')
        time.sleep(1)
def thread2():
    pv = epics.PV('prefix:long')
    while True:
        val = pv.get()
        print(f'thread2: {val}')
        time.sleep(1)
t1 = threading.Thread(target=thread1, daemon=True)
t2 = threading.Thread(target=thread2, daemon=True)
t1.start()
t2.start()
time.sleep(10)
Example that works; note the only change is the movement of the .iocInit() line down into thread1:
import os
import time
import threading
try:
except ImportError:
    pass
import epics
def thread1():
    softioc.iocInit()
    while True:
        val = long.get()
        long.set(val + 1)
        time.sleep(1)
def thread2():
    while True:
        val = pv.get()
        time.sleep(1)
t1.start()
t2.start()
time.sleep(10)
The output when it fails:
$ python3 ./demoFailingDaemon.py
Starting iocInit
## EPICS 7.0.6.0
## Rev. 7.0.6.99.1.0
thread1: 1
thread1: 2
thread1: 3
thread2: None
thread1: 4
thread1: 5
thread2: None
thread1: 6
thread1: 7
thread1: 8
thread2: None
thread1: 9
thread1: 10
thread1: 11
The output when it works:
$ python3 ./demoWorkingDaemon.py
Starting iocInit
## EPICS 7.0.6.0
thread1: 1
thread2: 2
thread1: 2
thread2: 3
thread1: 3
thread2: 4
thread1: 4
thread2: 5
thread1: 5
thread2: 6
thread1: 6
thread2: 7
thread1: 7
thread2: 8
thread1: 8
thread2: 9
thread1: 9
thread2: 10
thread1: 10
thread2: 11
Paul
Description: Description: cid:image001.jpg@01CB39FD.C1593830
Paul Richards
Software Engineer
W. M. Keck Observatory
65-1120 Mamalahoa Hwy.
Kamuela, Hawai'i 96743
Main: (808) 885-7887
Direct: (808) 881-3537
Fax: (808) 885-3535
Re: Weird channel access problem within Python softioc process Michael Davidsaver via Tech-talk
Re: Weird channel access problem within Python softioc process Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: RE: Getting started talking to a device Mark Rivers via Tech-talk
Next: Career Opportunities [NEW] for Accelerator Scientists Nicholas James Meyler via Tech-talk
Prev: Re: HiPace control via EDU TC 400 Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Weird channel access problem within Python softioc process Michael Davidsaver via Tech-talk
