Subject: Re: Weird channel access problem within Python softioc process
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Paul Richards <[email protected]>, "Abbott, Michael (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Wed, 11 Aug 2021 12:23:56 +0000
Hi Paul,
Import the pyepics and softioc libraries.
Something to be aware of, the default in pythonSoftIOC is to use cothread as its concurrency framework. It uses lightweight co-routines instead of OS threads. This means that you must be careful not to block the thread you call softioc.iocInit() in, otherwise the callbacks from caput and myrecord.set() will end up not being processed. Functions like softioc.interactive_ioc() will co-operatively block, allowing cothread to service callbacks in the background.
I can suggest a couple of things to try:
  • Either continue using cothread for concurrency, and use cothread.catools instead of pyepics for channel access. This will co-operatively block, allowing cothread to keep servicing the record callbacks
  • Or don't use cothread for concurrency. The only other supported concurrency framework at the moment is asyncio, but you could use that example to make a background thread dispatcher that did the same kind of thing as AsyncioDispatcher, but with a single background OS thread
Please could you put responses on the pythonSoftIOC issue that Michael created to track this.
Tom
From: Tech-talk <[email protected]> on behalf of Paul Richards via Tech-talk <[email protected]>
Sent: 11 August 2021 01:05
To: [email protected] <[email protected]>
Subject: Weird channel access problem within Python softioc process
All,
At Keck, we have been using the EPICS Python softioc with great success.  The recent 3.1 release has made it even more popular and easier to use.
That said, I have found a very odd behavior that I can replicate, relating to the consumption of keywords inside the same process that runs the softioc.  Sometimes it makes sense to do it this way, instead of finding a reference to the channel in the IOC and manipulating that.
A simplified example of the problem:
  1. Import the pyepics and softioc libraries.
  2. Start a softioc with a channel (call it ‘prefix:long’ in my example).
  3. Start a thread that periodically updates the channel with a new value.
  4. Start another thread that tries to access this channel, either with epics.PV() or epics.caget().
  5. Channel access in thread 2 always times out, forever.
Today I found a “solution” to this that does not make sense: if I start the softioc (the call to softioc.iotInit()) in the first thread, and not in the main process, everything works as expected.
Our engineers are unable to explain this behavior.  I hope there’s someone here on the list that might know why!
Example code that demonstrates the failure:
import os
import time
import threading
os.environ['EPICS_CA_SERVER_PORT'] = '5100'
os.environ['EPICS_CA_ADDR_LIST'] = 'localhost:5100'
os.environ['EPICS_CA_AUTO_ADDR_LIST'] = 'NO'
try:
    import epicscorelibs.path.pyepics
except ImportError:
    pass
import epics
from softioc import softioc, builder
# Create a long record for this demo
long = builder.longOut('prefix:long', initial_value=1)
builder.LoadDatabase()
softioc.iocInit()
def thread1():
    while True:
        val = long.get()
        long.set(val + 1)
        print(f'thread1: {val}')
        time.sleep(1)
def thread2():
    pv = epics.PV('prefix:long')
    while True:
        val = pv.get()
        print(f'thread2: {val}')
        time.sleep(1)
t1 = threading.Thread(target=thread1, daemon=True)
t2 = threading.Thread(target=thread2, daemon=True)
t1.start()
t2.start()
time.sleep(10)
Example that works; note the only change is the movement of the .iocInit() line down into thread1:
import os
import time
import threading
try:
except ImportError:
    pass
import epics
def thread1():
    softioc.iocInit()
    while True:
        val = long.get()
        long.set(val + 1)
        time.sleep(1)
def thread2():
    while True:
        val = pv.get()
        time.sleep(1)
t1.start()
t2.start()
time.sleep(10)
The output when it fails:
$ python3 ./demoFailingDaemon.py
Starting iocInit
## EPICS 7.0.6.0
## Rev. 7.0.6.99.1.0
thread1: 1
thread1: 2
thread1: 3
thread2: None
thread1: 4
thread1: 5
thread2: None
thread1: 6
thread1: 7
thread1: 8
thread2: None
thread1: 9
thread1: 10
thread1: 11
The output when it works:
$ python3 ./demoWorkingDaemon.py
Starting iocInit
## EPICS 7.0.6.0
thread1: 1
thread2: 2
thread1: 2
thread2: 3
thread1: 3
thread2: 4
thread1: 4
thread2: 5
thread1: 5
thread2: 6
thread1: 6
thread2: 7
thread1: 7
thread2: 8
thread1: 8
thread2: 9
thread1: 9
thread2: 10
thread1: 10
thread2: 11
Paul
Description: Description: cid:image001.jpg@01CB39FD.C1593830
Paul Richards
Software Engineer
W. M. Keck Observatory
65-1120 Mamalahoa Hwy.
Kamuela, Hawai'i 96743
Main: (808) 885-7887
Direct: (808) 881-3537
Fax: (808) 885-3535
Weird channel access problem within Python softioc process Paul Richards via Tech-talk
Prev: RE: ADURL with Axis PTZ network camera Heesterman, Peter J via Tech-talk
Next: Re: Weird channel access problem within Python softioc process Zhang, Tong via Tech-talk
Prev: Re: Weird channel access problem within Python softioc process Zhang, Tong via Tech-talk
Next: Career Opportunities [NEW] for Accelerator Scientists Nicholas James Meyler via Tech-talk
