Subject: Re: Trouble with macro substitutions
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Leblanc, Gregory" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 23 Aug 2021 16:43:04 +0000
Hi Greg,
On Aug 23, 2021, at 10:24 AM, Leblanc, Gregory via Tech-talk <[email protected]> wrote:
I’m having some trouble getting this substitution magic to work in my .db files.  I think that when I run ‘make’ I should get some .db files, which should have all of the $(XxX) stuff replaced, based on the contents of the .substitutions file, as long as the filenames match.  However, I’m getting some things replaced, and others not.  For example, I have the following in Watlow_PM_General.template:
        field(INPA,     "$(s):$(ta):$(ss):$(mod):ControlMode$(ch) CP")
And this in Watlow_PM_General.substitutions:
file Watlow_PM_General.template
pattern {  s, ta,      ss, mod, ch}
        {   , SE,  Watlow,   1,  1}
But when I compile, I get things like this in Watlow_PM_General.db:
        field(INPA,     "SE:Watlow:1:1:ControlMode$(ch) CP")
I haven’t been able to figure out why the ch macro is the only one not getting replaced.  Full source is at: https://github.com/gregoryleblanc/CsHeater
Well the obvious explanation is that the empty value intended for your $(s) macro in the substitutions file is being ignored — you have actually found a bug in our msi tool.
If it were setting $(s) to an empty string the PV name should begin with a colon character ‘:’ in the expanded version but it doesn’t — is that what you want to happen? For a workaround if you want $(s) to be empty you can do that by using an empty pair of double-quotes instead, I have just tried that and it works.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
Trouble with macro substitutions Leblanc, Gregory via Tech-talk
Prev: Re: [EXTERNAL] Trouble with macro substitutions Hartman, Steven via Tech-talk
Next: Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
