On Aug 23, 2021, at 11:43 AM, Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
Well the obvious explanation is that the empty value intended for your $(s) macro in the substitutions file is being ignored — you have actually found a bug in our msi tool.
Actually looking at the code both msi and the dbLoadTemplates() iocsh command ignore an empty pattern value, so I’m not sure that this is actually a bug, it looks to be be how the code was originally intended to work, so the fix would be to use empty quotes
for any empty macro values as I suggested before, either single or double quotes should work:
If it were setting $(s) to an empty string the PV name should begin with a colon character ‘:’ in the expanded version but it doesn’t — is that what you want to happen? For a workaround if you want $(s) to be empty you can do that by using an
empty pair of double-quotes instead, I have just tried that and it works.
- Andrew
Complexity comes for free, simplicity you have to work for.
- RE: Trouble with macro substitutions Leblanc, Gregory via Tech-talk
- Trouble with macro substitutions Leblanc, Gregory via Tech-talk
- Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
AD Stats with URL camera Profile problem Smith, William via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
