Subject: RE: Trouble with macro substitutions
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 24 Aug 2021 16:54:24 +0000
Thanks, that’s got the macro problem straightened out.  Not sure how any of this was really intended to work, yet.
    Greg
Sent: Monday, August 23, 2021 1:05 PM
To: Johnson, Andrew N. <[email protected]>
Cc: Leblanc, Gregory <[email protected]>; EPICS tech-talk <[email protected]>
Subject: Re: Trouble with macro substitutions
On Aug 23, 2021, at 11:43 AM, Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
Well the obvious explanation is that the empty value intended for your $(s) macro in the substitutions file is being ignored — you have actually found a bug in our msi tool.
Actually looking at the code both msi and the dbLoadTemplates() iocsh command ignore an empty pattern value, so I’m not sure that this is actually a bug, it looks to be be how the code was originally intended to work, so the fix would be to use empty quotes for any empty macro values as I suggested before, either single or double quotes should work:
If it were setting $(s) to an empty string the PV name should begin with a colon character ‘:’ in the expanded version but it doesn’t — is that what you want to happen? For a workaround if you want $(s) to be empty you can do that by using an empty pair of double-quotes instead, I have just tried that and it works.
- Andrew
Complexity comes for free, simplicity you have to work for.
Trouble with macro substitutions Leblanc, Gregory via Tech-talk
Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
Prev: EPICS support for Keithley 6517A unavailable, does anyone have it? Adam Szwandziak - STFC UKRI via Tech-talk
Next: Re: LIB_LIBS getting ignored Johnson, Andrew N. via Tech-talk
Prev: Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
Next: AD Stats with URL camera Profile problem Smith, William via Tech-talk
