On 8/25/21 12:19 PM, Hasan SANSAR via Tech-talk wrote:
> Hi all,
> I built aravisGigE R3-0 with areaDetector R3-3-1 and EPICS 3.15.8 on CentOS 7.9 on VirtualBox. I think there is no problem on building of EPICS, areaDetector and aravisGigE, because the driver was built.
> The other properties of my environment: asynDriver from GitHub, sequencer 2.2.9, autosave 5.7.1, busy 1.6.1, sscan 2.10, calc 3.6.1, ipac 2.7, iocStats on GitHub, ADCore R3-3-1, ADViewers R1-1, ADSupport R1-4.
> When I try to get informations from Baumer VLG-20M CCD camera with arv-tool-0.6, I'm getting warning "no device found". But, the commercial software of camera is running on my host machine(Linux Mint 21.04).
> And I can get ping from camera IP, but telnet command timed out.
> How can I solve this problem? Should I change environment I use? Or else, could it just be a network problem caused by a camera or CentOS 7.9?
It would help us to know if the 'arv-tool' CLI utility lists your camera.
cf. http://manpages.ubuntu.com/manpages/focal/en/man1/arv-tool-0.6.1.html
If it doesn't, I would suspect a network problem. Last I checked aravis
only did discovery by UDP broadcast, while some other clients have the
option for only UDP unicast. This was some years ago, so aravis might
be able to connect by IP address now.
Things to try. Check that both camera and computer have the same broadcast
address (and are on the same network segment). Check for firewall rules
effecting broadcasts.
fyi. Wireshark can decode some GVCP protocol messages.
- aravisGigE: no device found Hasan SANSAR via Tech-talk
EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
<2021>
2025
2026
Re: aravisGigE: no device found Mark Rivers via Tech-talk
<2021>
2025
2026
