You need to get arv-tool to work before aravisGigE or ADAravis will work.
> And I can get ping from camera IP, but telnet command timed out
telnet is not expected to work to a camera. What port are you trying to telnet to?
Try disabling any firewall.
Sent from my iPhone
> On Aug 25, 2021, at 3:19 PM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
> Hi all,
> I built aravisGigE R3-0 with areaDetector R3-3-1 and EPICS 3.15.8 on CentOS 7.9 on VirtualBox. I think there is no problem on building of EPICS, areaDetector and aravisGigE, because the driver was built.
> The other properties of my environment: asynDriver from GitHub, sequencer 2.2.9, autosave 5.7.1, busy 1.6.1, sscan 2.10, calc 3.6.1, ipac 2.7, iocStats on GitHub, ADCore R3-3-1, ADViewers R1-1, ADSupport R1-4.
> When I try to get informations from Baumer VLG-20M CCD camera with arv-tool-0.6, I'm getting warning "no device found". But, the commercial software of camera is running on my host machine(Linux Mint 21.04).
> And I can get ping from camera IP, but telnet command timed out.
> How can I solve this problem? Should I change environment I use? Or else, could it just be a network problem caused by a camera or CentOS 7.9?
> Hasan Sansar
- aravisGigE: no device found Hasan SANSAR via Tech-talk
EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Re: EPICS sequencer web page redirect problems Johnson, Andrew N. via Tech-talk
<2021>
2025
2026
Re: aravisGigE: no device found Michael Davidsaver via Tech-talk
<2021>
2025
2026
