Subject: Re: EPICS sequencer web page redirect problems
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 26 Aug 2021 00:47:15 +0000
The APS “Common Support Modules" page at https://epics.anl.gov/modules/common.php also pointed to the same address, but those links should be to https://www-csr.bessy.de/control/SoftDist/sequencer/ which works for me (just change http: into https:).
It appears that the web-server's http redirector isn’t actually pointing to the https web-server, resulting in infinite loops.
I just fixed the http: links on the APS EPICS website, including the one above.
- Andrew
On Aug 25, 2021, at 3:25 PM, Kevin Peterson via Tech-talk <[email protected]> wrote:
The sequencer page:
 http://epics.web.psi.ch/software/sequencer/
Says the EPICS sequencer now lives here:
 http://www-csr.bessy.de/control/SoftDist/sequencer
But trying to access that page in firefox results in this error:
 The page isn’t redirecting properly
 Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
And attempting to wget the 2.2.9 release results in these errors:
 $ wget http://www-csr.bessy.de//control/SoftDist/sequencer/releases/seq-2.2.9.tar.gz
 --2021-08-25 15:16:43-- http://www-csr.bessy.de//control/SoftDist/sequencer/releases/seq-2.2.9.tar.gz
 Resolving www-csr.bessy.de (www-csr.bessy.de)... 193.149.12.250
 Connecting to www-csr.bessy.de (www-csr.bessy.de)|193.149.12.250|:80... connected.
 HTTP request sent, awaiting response... 302 Found
 Location: http://www-csr.bessy.de//control/SoftDist/sequencer/releases/seq-2.2.9.tar.gz [following]
 Reusing existing connection to www-csr.bessy.de:80.
 <snipped 18 identical messages>
 --2021-08-25 15:16:45-- http://www-csr.bessy.de//control/SoftDist/sequencer/releases/seq-2.2.9.tar.gz
 20 redirections exceeded.
Complexity comes for free, simplicity you have to work for.
Re: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Prev: Re: aravisGigE: no device found Mark Rivers via Tech-talk
Next: RE: LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
Prev: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Next: Re: EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
