Subject: Windows: Problem building EPICS base, using MSYS2 & mingw
From: Luka Krmpotic via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 9 Sep 2021 14:54:27 +0200 (CEST)
Hello,
Following instructions here:
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows-msys2.html
in order to build EPICS base on Windows, using MSYS2 (x64) & mingw (x64).
Build failed looking for <direct.h>
The problem was that compiler being used was
/usr/bin/gcc.exe
instead of
/mingw64/bin/gcc.exe
I solved the problem by prepending /mingw64/bin: to $PATH in my ~/.bashrc,
which wasn't part of the $PATH in the default install.
[[ $PATH != *"/mingw64/bin"* ]] && PATH=/mingw64/bin:${PATH}
Best,
Luka
Re: Windows: Problem building EPICS base, using MSYS2 & mingw Ralph Lange via Tech-talk
Re: Windows: Problem building EPICS base, using MSYS2 & mingw Luka Krmpotic via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
Next: RE: Cannot build StreamDevice on Windows 64bit Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Heinz Junkes via Tech-talk
Next: Re: Windows: Problem building EPICS base, using MSYS2 & mingw Ralph Lange via Tech-talk
