Subject: RE: Cannot build StreamDevice on Windows 64bit
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
Date: Thu, 9 Sep 2021 13:02:36 +0000
Or maybe
#define strncasecmp strnicmp
On WIN32
Freddie
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: 09 September 2021 13:13
To: EPICS Tech Talk <[email protected]>
Subject: Re: Cannot build StreamDevice on Windows 64bit
Hi Johannes,
On Thu, 9 Sept 2021 at 14:02, Lehmeyer, Johannes via Tech-talk <[email protected]> wrote:
C:/msys64/mingw64/x86_64-w64-mingw32/include/string.h:113:15: error: conflicting declaration of 'int strncasecmp(const char*, const char*, size_t)' with 'C' linkage
  113 |   int __cdecl strncasecmp (const char *, const char *, size_t);
../ChecksumConverter.cc:50:12: note: previous declaration with 'C++' linkage
   50 | static int strncasecmp(const char *s1, const char *s2, size_t n)
In file included from ../StreamBuffer.h:26,
                 from ../StreamFormatConverter.h:27,
                 from ../ChecksumConverter.cc:58:
C:/msys64/mingw64/x86_64-w64-mingw32/include/string.h:116:28: error: redefinition of 'int strncasecmp(const char*, const char*, size_t)'
  116 |   __CRT_INLINE int __cdecl strncasecmp (const char *__sz1, const char *__sz2, size_t __sizeMaxCompare) { return _strnicmp (__sz1, __sz2, __sizeMaxCompare); }
../ChecksumConverter.cc:50:12: note: 'int strncasecmp(const char*, const char*, size_t)' previously defined here
If you look at that place, there's a hint:
#if defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
// These systems have no strncasecmp
Windows does not have str[n]casecmp(), so Stream provides an implementation.
MSYS2 does have it, so you need to fix the preprocessor #if to not provide the function under MSYS2.
Don't forget to offer your fix upstream as a PullRequest.
Cheers,
~Ralph
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
Cannot build StreamDevice on Windows 64bit Lehmeyer, Johannes via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
Prev: Windows: Problem building EPICS base, using MSYS2 & mingw Luka Krmpotic via Tech-talk
Next: Re: Windows: Problem building EPICS base, using MSYS2 & mingw Ralph Lange via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
Next: Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
