Subject: Re: Cannot build StreamDevice on Windows 64bit
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
Date: Fri, 10 Sep 2021 07:46:49 +0000
On Thu, 2021-09-09 at 13:02 +0000, Freddie Akeroyd - STFC UKRI via Tech-talk wrote:
> If you look at that place, there's a hint:
> > #if defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
> > // These systems have no strncasecmp
> > static int strncasecmp(const char *s1, const char *s2, size_t n)
Does anyone know the situation in RTEMS 5?
If RTEMS 5 has strncasecmp, how to branch correctly?
Re: Cannot build StreamDevice on Windows 64bit Johnson, Andrew N. via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Heinz Junkes via Tech-talk
Cannot build StreamDevice on Windows 64bit Lehmeyer, Johannes via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
RE: Cannot build StreamDevice on Windows 64bit Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
Next: Re: Windows: Problem building EPICS base, using MSYS2 & mingw Luka Krmpotic via Tech-talk
Next: Re: Cannot build StreamDevice on Windows 64bit Johnson, Andrew N. via Tech-talk
