Why not just switch to using epicsStrnCaseCmp() in epicsString.h? We’ve already solved the portability issues there.
- Andrew
On Sep 10, 2021, at 2:46 AM, Zimoch Dirk (PSI) via Tech-talk < [email protected]> wrote:
On Thu, 2021-09-09 at 13:02 +0000, Freddie Akeroyd - STFC UKRI via Tech-talk wrote:
If you look at that place, there's a hint:
#if defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
// These systems have no strncasecmp
static int strncasecmp(const char *s1, const char *s2, size_t n)
Does anyone know the situation in RTEMS 5?
If RTEMS 5 has strncasecmp, how to branch correctly?
Complexity comes for free, simplicity you have to work for.
- Cannot build StreamDevice on Windows 64bit Lehmeyer, Johannes via Tech-talk
- Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
- RE: Cannot build StreamDevice on Windows 64bit Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
Re: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Shen, Guobao via Tech-talk
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Matt Newville via Tech-talk
<2021>
2025
2026
Re: Cannot build StreamDevice on Windows 64bit Heinz Junkes via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
