Subject: Re: Cannot build StreamDevice on Windows 64bit
From: Heinz Junkes via Tech-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 10 Sep 2021 17:31:19 +0200
in rtems 5 this is defined in string.h:
int      strncasecmp(const char *, const char *, size_t) __pure;
and in Posix-Api Guide : https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/posix-users.html
Heinz
> On 10. Sep 2021, at 09:46, Zimoch Dirk (PSI) via Tech-talk <[email protected]> wrote:
> On Thu, 2021-09-09 at 13:02 +0000, Freddie Akeroyd - STFC UKRI via Tech-talk wrote:
>> If you look at that place, there's a hint:
>>> #if defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
>>> // These systems have no strncasecmp
>>> static int strncasecmp(const char *s1, const char *s2, size_t n)
> Does anyone know the situation in RTEMS 5?
> If RTEMS 5 has strncasecmp, how to branch correctly?
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Cannot build StreamDevice on Windows 64bit Lehmeyer, Johannes via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
RE: Cannot build StreamDevice on Windows 64bit Freddie Akeroyd - STFC UKRI via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
Prev: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Matt Newville via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Johnson, Andrew N. via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Johnson, Andrew N. via Tech-talk
Next: Windows: Problem building EPICS base, using MSYS2 & mingw Luka Krmpotic via Tech-talk
