Hi Wanming,
Those errors may not prevent ADAravis from working. For example most but not all cameras have the SensorWidth feature, but ADAravis does not require it. It
does require WidthMax. Similarly, many cameras do not have a GainRaw feature.
What happens if you run arv-tool-0.8 to extract the XML file, use the Python scripts to generate the template and OPI files, and then try to run an ADAravis
IOC with the camera?
Liu, Wanming via Tech-talk
Sent: Thursday, September 9, 2021 9:54 AM
To: [email protected]
Subject: Using ADAravis with Spectral Instrument 1700 Radiation hard camera
We recently bought a few radiation hard GigE cameras from Spectral Instruments Inc. I’m just wondering if anybody has any experience using them with ADAravis.
We have no problem using ADAravis with other GigE camera we have. But so far there is no success with this Spectral Instruments 1700 radiation hard camera.
When I checked it with arv-test-0.8.exe, it reports several errors.
$ arv-test-0.8.exe
Found 1 device
Testing 'Spectral Instruments, Inc.:1700'
Genicam:Load
SUCCESS
Genicam:Schema
IGNORED
Properties:SensorSizeReadout
FAILURE node 'SensorWidth' not found
Properties:SensorSizeCheck
IGNORED
Properties:GainReadout
FAILURE node 'GainRaw' not found
Properties:ExposureTimeReadout
SUCCESS
MultipleAcquisition:BufferCheck
FAILURE node 'TriggerSelector' not found
SingleAcquisition:BufferCheck
FAILURE
Chunks:NoSupport FAILURE
SoftwareTrigger:NoSupport
FAILURE
GigEVision:NStreamChannels
SUCCESS
GigEVision:StreamChannel
SUCCESS
Any comments and suggestions are appreciated.
Wanming Liu
