Subject: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera
From: "Liu, Wanming via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Date: Thu, 9 Sep 2021 18:43:05 +0000
Hi Mark,
Thanks for your response.
When use addCamera.sh in ADGenICam with the XML file extracted with arv-tool-0.8, it shows a bunch of don’t know what to do with IntReg.  Based on the ADAravis documentation, it should be fine.
Don't know what to do with MaskedIntReg
Don't know what to do with IntReg
Then I copied one of the st.cmd…  file into st.cmd.si and modified it as following
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/ADAravisApp.dbd")
ADAravisApp_registerRecordDeviceDriver(pdbbase)
# Name of camera as reported by arv-tool
epicsEnvSet("CAMERA_NAME", "Spectral Instruments, Inc.-1700-139")
# The maximum image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "2048")
# The maximum image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1088")
# Define NELEMENTS to be enough for a 2048x1088 mono image
epicsEnvSet("NELEMENTS", "22228224")
# Enable register caching
epicsEnvSet("ENABLE_CACHING", "1")
# The database file
epicsEnvSet("GENICAM_DB_FILE", "$(ADGENICAM)/db/si.template")
< st.cmd.base
Then I launched IOC and every thing looks fine.  The problem was when I tried to acquire data from the camera.
When I tried to acquire data from the camera,  the IOC complained about
ADAravis::newBufferCallback bad frame status: Timeout
or sometimes
ADAravis::newBufferCallback bad frame status: Missing Pkts.
while no image can be displayed on the OPI.
It might be some camera setting issues or network setting issue.
Thanks for advices
Wanming
Sent: Thursday, September 9, 2021 10:18 AM
To: Liu, Wanming <[email protected]>
Cc: [email protected]
Hi Wanming,
Those errors may not prevent ADAravis from working.  For example most but not all cameras have the SensorWidth feature, but ADAravis does not require it.  It does require WidthMax.  Similarly, many cameras do not have a GainRaw feature.
What happens if you run arv-tool-0.8 to extract the XML file, use the Python scripts to generate the template and OPI files, and then try to run an ADAravis IOC with the camera?
From: Tech-talk <[email protected]> On Behalf Of Liu, Wanming via Tech-talk
Sent: Thursday, September 9, 2021 9:54 AM
To: [email protected]
Subject: Using ADAravis with Spectral Instrument 1700 Radiation hard camera
We recently bought a few radiation hard GigE cameras from Spectral Instruments Inc.  I’m just wondering if anybody has any experience using them with ADAravis.
We have no problem using ADAravis with other GigE camera we have.  But so far there is no success with this Spectral Instruments 1700 radiation hard camera.
When I checked it with arv-test-0.8.exe, it reports several errors.
$ arv-test-0.8.exe
Found 1 device
Testing 'Spectral Instruments, Inc.:1700'
Genicam:Load                        SUCCESS
Genicam:Schema                      IGNORED
Properties:SensorSizeReadout        FAILURE node 'SensorWidth' not found
Properties:SensorSizeCheck          IGNORED
Properties:GainReadout              FAILURE node 'GainRaw' not found
Properties:ExposureTimeReadout      SUCCESS
MultipleAcquisition:BufferCheck     FAILURE node 'TriggerSelector' not found
SingleAcquisition:BufferCheck       FAILURE
Chunks:NoSupport                    FAILURE
SoftwareTrigger:NoSupport           FAILURE
GigEVision:NStreamChannels          SUCCESS
GigEVision:StreamChannel            SUCCESS
Any comments and suggestions are appreciated.
Wanming Liu
RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Prev: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
Next: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Next: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
