Subject: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
Cc: Francesco De Carlo <[email protected]>, "'Veseli, Sinisa'" <[email protected]>, "Nikitin, Viktor" <[email protected]>
Date: Thu, 9 Sep 2021 19:05:04 +0000
Folks,
I believe there is an incompatibility of the Python pyepics and pvapy packages on Windows.  I have a Python application called tomoscan that uses both packages.
https://github.com/tomography/tomoscan
This works fine on Linux.  It used to work OK on Windows.  However, using the latest versions of pyepics (3.5.0) and pvapy (4.0.0) it crashes as follows on startup:
(tomoscan) J:\epics\support\tomoscan\iocBoot\iocTomoScan_13BM_PSO>python -i start_tomoscan.py
Exception in thread Thread-1:
Traceback (most recent call last):
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 932, in _bootstrap_inner
    self.run()
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 870, in run
    self._target(*self._args, **self._kwargs)
  File "\\corvette\people_rw\epics\support\tomoscan\tomoscan\tomoscan.py", line 240, in reset_watchdog
    self.epics_pvs['Watchdog'].put(5)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 54, in wrapped
    return func(self, *args, **kwargs)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 652, in put
    return ca.put(self.chid, value,
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 610, in wrapper
    return fcn(*args, **kwds)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 1717, in put
    poll()
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 547, in wrapper
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 923, in poll
    pend_event(evt)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 910, in pend_event
    ret = libca.ca_pend_event(timeout)
OSError: exception: access violation reading 0x0000000000000048
Note that it is crashing with an access violation in the ca_pend_event() in the C library.  This happens when epics.PV.put() is called in a different Python thread.
I suspect the problem is that the version of ca.dll that comes with pvapy is somehow incompatible with pyepics.
This suspicion comes from the fact that I can modify the tomoscan package so that it does not use pvaccess by commenting out the 2 lines shown below in __init__py:
corvette:~/support/tomoscan/tomoscan>more __init__.py
__version__ = '0.1'
from tomoscan.tomoscan import *
from tomoscan.tomoscan_pso import *
from tomoscan.tomoscan_step import *
#from tomoscan.tomoscan_stream_pso import *
from tomoscan.tomoscan_13bm_pso import *
from tomoscan.tomoscan_13bm_mcs import *
from tomoscan.tomoscan_2bm import *
from tomoscan.tomoscan_2bm_step import *
from tomoscan.tomoscan_6bm_step import *
from tomoscan.tomoscan_32id import *
from tomoscan.tomoscan_32id_step import *
#from tomoscan.tomoscan_stream_2bm import *
from tomoscan.tomoscan_7bm import *
.tomoscan_stream_pso and .tomoscan_stream_2bm are the only files that use pvaccess.
With those 2 lines commented out tomoscan starts fine:
However, I can cause it to crash again by telling pyepics to use the version of ca.dll that is part of pvapy using the environment variable PYEPICS_LIBCA.
>set PYEPICS_LIBCA=C:\Users\rivers\Anaconda3\envs\tomoscan\Lib\site-packages\pvaccess\ca.dll
    self.run()
    poll()
    pend_event(evt)
This is pretty good evidence that the problem is due to some problem with the version of ca.dll that comes with pvapy 4.0.0.
If I downgrade pvapy from 4.0.0 to the previous version, 3.1.0 it works fine, using the original __init__.py that enables pvaccess.  This is true whether or not PYEPICS_LIBCA is defined to point to the pvaccess version of ca.dll.  It seems like there is some problem with the ca.dll that comes with pvapy 4.0.0.
Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Prev: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Next: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Mark Rivers via Tech-talk
Next: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Veseli, Sinisa via Tech-talk
