I wrote a very simple test program which I would have expected to fail, since it implements the same logic as the startup error in tomoscan.
corvette:~/support/tomoscan/tomoscan>more test_ca.py
import pvaccess
import epics
import threading
import time
class test_ca():
def __init__(self):
thread = threading.Thread(target=self.test_put, args=(), daemon=True)
thread.start()
def test_put(self):
pv = epics.PV('13BMDPG1:cam1:AcquireTime')
while True:
print("Setting PV to 0.1")
pv.put(0.1)
time.sleep(3)
However, I cannot make it fail, even by setting PYEPICS_LIBCA to point to the pvaccess version of ca.dll.
Folks,
I believe there is an incompatibility of the Python pyepics and pvapy packages on Windows. I have a Python application called tomoscan that uses both packages.
https://github.com/tomography/tomoscan
This works fine on Linux. It used to work OK on Windows. However, using the latest versions of pyepics (3.5.0) and pvapy (4.0.0) it crashes as follows on startup:
(tomoscan) J:\epics\support\tomoscan\iocBoot\iocTomoScan_13BM_PSO>python -i start_tomoscan.py
Exception in thread Thread-1:
Traceback (most recent call last):
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 932, in _bootstrap_inner
self.run()
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "\\corvette\people_rw\epics\support\tomoscan\tomoscan\tomoscan.py", line 240, in reset_watchdog
self.epics_pvs['Watchdog'].put(5)
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 54, in wrapped
return func(self, *args, **kwargs)
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 652, in put
return ca.put(self.chid, value,
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 610, in wrapper
return fcn(*args, **kwds)
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 1717, in put
poll()
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 547, in wrapper
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 923, in poll
pend_event(evt)
File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 910, in pend_event
ret = libca.ca_pend_event(timeout)
OSError: exception: access violation reading 0x0000000000000048
Note that it is crashing with an access violation in the ca_pend_event() in the C library. This happens when epics.PV.put() is called in a different Python
thread.
I suspect the problem is that the version of ca.dll that comes with pvapy is somehow incompatible with pyepics.
This suspicion comes from the fact that I can modify the tomoscan package so that it does not use pvaccess by commenting out the 2 lines shown below in __init__py:
corvette:~/support/tomoscan/tomoscan>more __init__.py
__version__ = '0.1'
from tomoscan.tomoscan import *
from tomoscan.tomoscan_pso import *
from tomoscan.tomoscan_step import *
#from tomoscan.tomoscan_stream_pso import *
from tomoscan.tomoscan_13bm_pso import *
from tomoscan.tomoscan_13bm_mcs import *
from tomoscan.tomoscan_2bm import *
from tomoscan.tomoscan_2bm_step import *
from tomoscan.tomoscan_6bm_step import *
from tomoscan.tomoscan_32id import *
from tomoscan.tomoscan_32id_step import *
#from tomoscan.tomoscan_stream_2bm import *
from tomoscan.tomoscan_7bm import *
.tomoscan_stream_pso and .tomoscan_stream_2bm are the only files that use pvaccess.
With those 2 lines commented out tomoscan starts fine:
However, I can cause it to crash again by telling pyepics to use the version of ca.dll that is part of pvapy using the environment variable PYEPICS_LIBCA.
>set PYEPICS_LIBCA=C:\Users\rivers\Anaconda3\envs\tomoscan\Lib\site-packages\pvaccess\ca.dll
self.run()
poll()
pend_event(evt)
This is pretty good evidence that the problem is due to some problem with the version of ca.dll that comes with pvapy 4.0.0.
If I downgrade pvapy from 4.0.0 to the previous version, 3.1.0 it works fine, using the original __init__.py that enables pvaccess. This is true whether or
not PYEPICS_LIBCA is defined to point to the pvaccess version of ca.dll. It seems like there is some problem with the ca.dll that comes with pvapy 4.0.0.
