Subject: Re: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: "De Carlo, Francesco" <[email protected]>, "Nikitin, Viktor" <[email protected]>
Date: Thu, 9 Sep 2021 20:03:07 +0000
Ho Mark,
This is not quite the same, as in your test application you first import pvaccess, while in tomoscan this seems to happen later. Also, in this code you are only using epics module.
Like I mentioned earlier, there were some threading-related changes in pvapy 4.0.0 that might be causing this.
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: Thursday, September 9, 2021 2:51 PM
To: '[email protected]' <[email protected]>
Cc: De Carlo, Francesco <[email protected]>; Veseli, Sinisa <[email protected]>; Nikitin, Viktor <[email protected]>
Subject: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
I wrote a very simple test program which I would have expected to fail, since it implements the same logic as the startup error in tomoscan.
corvette:~/support/tomoscan/tomoscan>more test_ca.py
import pvaccess
import epics
import threading
import time
class test_ca():
    def __init__(self):
        thread = threading.Thread(target=self.test_put, args=(), daemon=True)
        thread.start()
    def test_put(self):
         pv = epics.PV('13BMDPG1:cam1:AcquireTime')
         while True:
            print("Setting PV to 0.1")
            pv.put(0.1)
            time.sleep(3)
However, I cannot make it fail, even by setting PYEPICS_LIBCA to point to the pvaccess version of ca.dll.
Sent: Thursday, September 9, 2021 2:05 PM
To: [email protected]
Cc: 'Veseli, Sinisa' <[email protected]>; Matt Newville <[email protected]>; Francesco De Carlo <[email protected]>; Nikitin, Viktor <[email protected]>
Subject: Incompatibility of pyepics and pvaPy 4.0.0 on Windows
Folks,
I believe there is an incompatibility of the Python pyepics and pvapy packages on Windows.  I have a Python application called tomoscan that uses both packages.
https://github.com/tomography/tomoscan
This works fine on Linux.  It used to work OK on Windows.  However, using the latest versions of pyepics (3.5.0) and pvapy (4.0.0) it crashes as follows on startup:
(tomoscan) J:\epics\support\tomoscan\iocBoot\iocTomoScan_13BM_PSO>python -i start_tomoscan.py
Exception in thread Thread-1:
Traceback (most recent call last):
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 932, in _bootstrap_inner
    self.run()
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\threading.py", line 870, in run
    self._target(*self._args, **self._kwargs)
  File "\\corvette\people_rw\epics\support\tomoscan\tomoscan\tomoscan.py", line 240, in reset_watchdog
    self.epics_pvs['Watchdog'].put(5)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 54, in wrapped
    return func(self, *args, **kwargs)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\pv.py", line 652, in put
    return ca.put(self.chid, value,
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 610, in wrapper
    return fcn(*args, **kwds)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 1717, in put
    poll()
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 547, in wrapper
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 923, in poll
    pend_event(evt)
  File "C:\Users\rivers\Anaconda3\envs\tomoscan\lib\site-packages\epics\ca.py", line 910, in pend_event
    ret = libca.ca_pend_event(timeout)
OSError: exception: access violation reading 0x0000000000000048
Note that it is crashing with an access violation in the ca_pend_event() in the C library.  This happens when epics.PV.put() is called in a different Python thread.
I suspect the problem is that the version of ca.dll that comes with pvapy is somehow incompatible with pyepics.
This suspicion comes from the fact that I can modify the tomoscan package so that it does not use pvaccess by commenting out the 2 lines shown below in __init__py:
corvette:~/support/tomoscan/tomoscan>more __init__.py
__version__ = '0.1'
from tomoscan.tomoscan import *
from tomoscan.tomoscan_pso import *
from tomoscan.tomoscan_step import *
#from tomoscan.tomoscan_stream_pso import *
from tomoscan.tomoscan_13bm_pso import *
from tomoscan.tomoscan_13bm_mcs import *
from tomoscan.tomoscan_2bm import *
from tomoscan.tomoscan_2bm_step import *
from tomoscan.tomoscan_6bm_step import *
from tomoscan.tomoscan_32id import *
from tomoscan.tomoscan_32id_step import *
#from tomoscan.tomoscan_stream_2bm import *
from tomoscan.tomoscan_7bm import *
.tomoscan_stream_pso and .tomoscan_stream_2bm are the only files that use pvaccess.
With those 2 lines commented out tomoscan starts fine:
However, I can cause it to crash again by telling pyepics to use the version of ca.dll that is part of pvapy using the environment variable PYEPICS_LIBCA.
>set PYEPICS_LIBCA=C:\Users\rivers\Anaconda3\envs\tomoscan\Lib\site-packages\pvaccess\ca.dll
    self.run()
    poll()
    pend_event(evt)
This is pretty good evidence that the problem is due to some problem with the version of ca.dll that comes with pvapy 4.0.0.
If I downgrade pvapy from 4.0.0 to the previous version, 3.1.0 it works fine, using the original __init__.py that enables pvaccess.  This is true whether or not PYEPICS_LIBCA is defined to point to the pvaccess version of ca.dll.  It seems like there is some problem with the ca.dll that comes with pvapy 4.0.0.
RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Prev: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
Next: RE: Using ADAravis with Spectral Instrument 1700 Radiation hard camera Liu, Wanming via Tech-talk
Next: RE: Incompatibility of pyepics and pvaPy 4.0.0 on Windows Mark Rivers via Tech-talk
