Sorry, I’ve failed to link to the working git repo for my mess:
https://github.com/gregoryleblanc/CsHeater
The file in question is:
https://github.com/gregoryleblanc/CsHeater/blob/main/CsHeaterApp/Db/Watlow_PM_Monitor.template
I don’t have a head on the Pi running the softIoc, but I do have another linux box here. I’ll get CSS installed and see what it says. I can probably also get debugging info from the windows version, although the console output is very
noisy.
Greg
Sent: Tuesday, October 5, 2021 11:07 AM
To: Leblanc, Gregory <[email protected]>
Subject: Re: Odd characters in temperatures showing in Phoebus
If I understand correctly, you do have the UTF-8 0xc2b0 in the EPICS database file, good.
caget on Linux also shows that as a degree sign.
Can you run CSS on Linux to see what comes up in the GUI?
It's possible that it all works on Linux because UTF-8 tends to be the default there.
On Windows we might be missing something in the CSS code to select UTF-8, so we end up with some other default and thus the characters are not correctly mapped.
Looking at Watlow_PM_Monitor.template in Notepad++ with the HEX editor installed, I see that it is already showing 0xC2 0xB0 (screenshot attached).
When I look at the Windows ANSI (windows-1252) code page, I see that 0xC2 is for Latin Capital letter A with circumflex, and 0xB0 is degree sign. So that explains why I’m seeing the double characters in Phoebus, though not what to do
about it.
Next I tried running “> caget -d CTRL_DOUBLE SP_Cesium:Oven_Heater:ProcessValue1 > bad.txt
That command always shows the strange character, regardless of what is displayed on the console. When I open that file in notepad++, I get the strange T character. When I look at the hex dump, it shows the “┬”
character is encoded as 0x2c 0x25. It also shows a “░” character with an encoding of 0x91 0x25.
‘file bad.txt’ from WSL reports:
bad.txt: Little-endian UTF-16 Unicode text, with CRLF line terminators
I don’t seem to get the strange character encoding when I run caget from linux, which would make sense if it’s somehow related to the windows codepage.
Greg
Sent: Monday, October 4, 2021 4:52 PM
Well, try to use some type of hex editor to edit the database file and make it
Well, that gives me some interesting results.
Full dump at:
https://pastebin.com/4iqDBfem
TL;DR:
Units:
> ssh elsewhere & return
Units: °
Same behavior using PowerShell and command prompt. I don’t see any change to $OutputEncoding before or after the ssh command, nor does manually setting $OutputEncoding = [System.Text.Encoding]::UTF8 make any difference. Chcp reports
the same active code page before and after ssh (437), so that doesn’t seem to be the right direction. I don’t have hexdump on windows, yet.
Greg
> caget SP_Cesium:Oven_Heater:ProcessValue1
SP_Cesium:Oven_Heater:ProcessValue1 22.855
Try
and note the 'Units'.
Also try
caget -d CTRL_DOUBLESP_Cesium:Oven_Heater:ProcessValue1 | hexdump -c
to see exactly what characters follow the "Units:"...
Fundamentally, phoebus will allow UTF-8 encoded text for the units.
-Kay
