1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EPICS 7.0.6.1 Released
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 11 Oct 2021 20:59:41 +0000
The EPICS Core Developers are pleased to announce the availability of this new EPICS release.
This bug-fix release contains bug fixes and some changes in libCom, the IOC, and the pvAccess CA provider. Please see the Release Notes for details. Users of EPICS 7.0.6 on Windows should upgrade to this release to obtain the fix for epicsTimers on non-EPICS threads. Users of the mbboDirect record should also read the specific Record Reference page for additional information about changes to that record type.
The software source code can be obtained from all of the normal locations.
Many thanks to everyone who contributed code, documentation updates, bug reports and testing.
Contributors:
Andrew Johnson
Dirk Zimoch
Freddie Akeroyd
J. Lewis Muir
Jeremy Lorelli
Kay Kasemir
Michael Davidsaver
Sinisa Veseli
Torsten Bögershausen
Commits:
epics-base/7.0:
abfe30ef1 Set version numbers for release
9895ee8b5 Release notes
78b744138 Checkout submodules for release
48d070d29 UNRELEASED => EPICS 7.0.6.1 for Release
a5864e152 Adjust Doxygen annotation comments
b6da75827 Merge the mbboDirect-bit-fields branch into 7.0
e867b0a09 mbboDirect: Document the behavior changes
dabcf893f mbboDirect: Fix initialization from VAL vs. B*
bf2cdc9f6 mbboDirect: Remove debugging db_post_events() calls
9c1340d7d cleanup mbboDirect bit field handling
59ee7b32b "Desired Output": change "Loc" to "Link" in prompt string
3f43b0bb8 Record POD updates
2ce583fff Apply suggested changes to DEBUG fixes
98aac49a8 Merge Torsten's FixCompilationErrorsForDEBUG branch
420fb45fb Fix several compilation errors for -DDEBUG
66ff5a7bb Update pvAccess submodule
23e55bf24 Makefile tweak
687dad47d aSub POD: Note about accessing the NOT field
7d2ca62a7 Misc doxygen fixes and updates
3d09106b5 Merge 3.15 branch into 7.0
5cddcea82 Change the epicsTimerTest delayVerify failure condition
9b69e63a6 Update GHA config, drop Ubuntu-16.04 builds
422513990 Release notes for Win32 timer fix.
331386069 Win32 osdThread.c polishing
2b8eb97b7 Merge Freddie's refactor_get_param_win32 branch
00e9ecf7b Fix typo in osdThreadGetTimer
65b34874b Check for NULL in osdThreadGetTimer
939d84f31 Refactor to use common epicsThreadGetParamWIN32() function
9842bd1b2 Prefer to install %.html files from O.Common
e7ea81c7a Reference doc tweaks to the dfanout record
c528948f4 Adjust build rules for POD to HTML conversion
fe4050b8c Workaround for RTEMS-mv2[17]00 parallel builds
1fd7190cf Fix RTEMS-4 uC5282 build and atomic typos
8e2f78caf dbStatic: Better error reports for bad JSON string chars
33ffabaa9 Minimum Perl version is 5.10.1
7ce69155a test regressLinkSevr
f6e8a7502 Fix DB link to DBF_MENU as DBF_STRING
88079c910 long CALC$ regressTest
82ec539e4 Fix long string handling for CALC$
e34b6c5c0 Fix spelling in comments
42d06d6a3 Fix bugs in dbRecordNameValidate()
21e7e4ddf cleanup regressTest
4efa93742 Merge Lewis' calcout-doc-fix branch into 7.0
8e11406fc Fix calcout rec doc typo: s/If it met/If met/
a0ab5aa4a Merge Kay's int64in_monitor branch into 7.0
3091f7c56 int64in: Fix monitor delta test
7c6d04969 Merge branch 'gcc-atomic-cleanup' into 7.0
540a5c87d Adjust wording of classification descriptions
a667cc7aa Move GCC+Clang common headers to a new file
78d2f20fa Com: Adjust epicsAtomic conditionals for GCC
8175cc8e6 POD text updates to dbCommon and various record types
72626cd5d Add newlines to a couple iocsh usage strings
8beb7bd2c Restore the -p flag to MKDIR which RTEMS host.cfg removes
cb8c7998b epicsTime: rework
7c991f3f2 Fix segfault in dbtpn when value parameter is nullptr
32d76623f Fix potential memory leak on error
ec87b2a86 recGbl: Update to using dbGetTimeStampTag()
7a6aa3edd waveform: Update POD, describe BUSY field
16c320299 waveform: Add back lost PACT = TRUE
967846b95 tap files are PRECIOUS
e5aece682 ci: replace GHA deprecated ubuntu-16.04 with CentOS/Fedora builds
f801ca050 Drop version number from README
936305295 Update submodules after release
f5cb3cf8f Update version numbers after tagging
pvAccessCPP/master:
de20a37b Set version numbers for release
e452aa7d GHA: Back out cache key changes but add rtems_target
a58ed6f9 GHA: Fix oops in key
99925ba6 Updated release notes for PVA 7.1.5 (EPICS 7.0.6.1)
a08c1bcc Delete a few obsolete text files
37b6a8f9 GHA: Change cache key to trigger reconstruction for RTEMS-4.9
99432d68 caProvider: Minor cleanup
161eac3a caProvider: speed up monitor list handling
671f5a40 caProvider: Speed up addChannel()
75e3d9e1 Appveyor configuration tweaks
0929d661 Update .ci version and CI-builder configurations
7240f97e Fix error string in ca/dbdToPv.cpp
cd152c37 add checks for null pointers
9a88e5e8 fix issue with null pointer check for DBR_ENUM
deefe124 avoid probleem with pv structures that do not have value subfield
a5cae7ad Set next development version
- Andrew Johnson, on behalf of the EPICS Core Developers Group
Complexity comes for free, simplicity you have to work for.
Prev: RE: Control System Studio vs Phoebus Leblanc, Gregory via Tech-talk
Next: Support for recent general purpose oscilloscopes? Brown, Garth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Control System Studio vs Phoebus Manoussakis, Adamandios via Tech-talk
