Subject: Re: Measurement Computing USB-1608G_2AO support
To: Mark Rivers <[email protected]>, "'Dudley, David'" <[email protected]>
Date: Thu, 21 Oct 2021 21:43:11 +0000
Hi Mark, David, etc.:
Those modules seem amazing. Do you know any analog I/O modules accept external trigger, i.e. it has an TTL trigger input?
Yong
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Monday, October 18, 2021 at 7:33 PM
To: 'Dudley, David' <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: Measurement Computing USB-1608G_2AO support
Hi David,
The high level EPICS software already exists in this file, which works on both Linux and Windows.
https://github.com/epics-modules/measComp/blob/master/measCompApp/src/drvMultiFunction.cpp
The low-level Linux driver for the USB-1608G-2A0, written by Warren Jasper, also already exists:
https://github.com/wjasper/Linux_Drivers/blob/master/USB/mcc-libusb/usb-1608G.c
All that needs to be done is to write the “glue layer”, which is the derived class mcBoard_USB-1608G.cpp, in this directory:
https://github.com/epics-modules/measComp/tree/master/measCompApp/cbw_linuxSrc
There are lots of examples, including the mcBoard_E-1608.cpp that can be used as a starting point.
From: Tech-talk <[email protected]> On Behalf Of Dudley, David via Tech-talk
Sent: Monday, October 18, 2021 2:29 PM
To: [email protected]
Subject: Measurement Computing USB-1608G_2AO support
Anyone implemented support for these device under Linux?  measComp module looked real promising until read that only certain modules are supported under Linux, and this one is not one of them.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Prev: RE: QuadEM operation with parameters "Queued" Iain Marcuson via Tech-talk
Next: Waveform Generator Proteus Model P2588D -- EPICS Device support Luchini, Kristi L. via Tech-talk
Prev: RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Next: RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
