I've built motor-R7-2-2 against base-7.0.4.1 on RHEL8, but I haven't
built anything against base-7.0.6.1 yet. I'll test that tomorrow.
Kevin
On 10/21/21 11:48, Johnson, Andrew N. wrote:
I suspect this build error may be due to the updated version of g++ that
comes with CentOS-8/RHEL-8 which has stricter language rules than the
Motor support was written for (Kevin — have you tried building Motor
using RHEL-8 yet? I’d expect you to see exactly the same errors there).
- Re: motor module make error Kevin Peterson via Tech-talk
- motor module make error 网易邮件中心 via Tech-talk
- Re: motor module make error Johnson, Andrew N. via Tech-talk
RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Re: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
