Subject: Re: motor module make error
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, 网易邮件中心 <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 22 Oct 2021 11:49:48 -0500
I was able to build the master branch of motor against base-7.0.6.1 on RHEL8. I used a custom assemble_synApps config file, motor-rhel8-test, that I created manually. Here are the steps I took:
# Obtain and build EPICS base
$ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz
$ tar xzvf base-7.0.6.1.tar.gz
$ cd base-7.0.6.1
$ export EPICS_HOST_ARCH=linux-x86_64
$ make
$ cd ..
# Obtain a subset of synApps modules
$ wget https://raw.githubusercontent.com/EPICS-synApps/support/master/assemble_synApps.sh
$ cat motor-rhel8-test
EPICS_BASE=/home/beams/KPETERSN/epics/base-7.0.6.1/
HAVE_HIDAPI=NO
WITH_PVA=YES
### The name of the synApps directory can be customized
SYNAPPS_DIR=synApps_rhel8
SUPPORT=R6-2-1
UTILS=R6-2-1
DOCUMENTATION=R6-2-1
ASYN=R4-42
AUTOSAVE=R5-10-2
BUSY=R1-7-3
CALC=R3-7-4
SNCSEQ=2.2.9
STD=R3-6-3
MOTOR=master
$ ./assemble_synApps.sh configs/motor-rhel8-test full
$ cd synApps_rhel8/support
# Manually edit RELEASE files
1. Comment out the following line from calc-R3-7-4/configure/RELEASE:
  SSCAN=$(SUPPORT)/sscan-2-9
2. Comment out the following line from motor-master/configure/RELEASE:
  IPAC=$(SUPPORT)/ipac-R2-15
# Build synApps
$ make
Note: if you build all the synApps modules it is much less likely that RELEASE files will need to be modified.
Kevin
On 10/21/21 17:40, Kevin Peterson wrote:
I've built motor-R7-2-2 against base-7.0.4.1 on RHEL8, but I haven't built anything against base-7.0.6.1 yet.  I'll test that tomorrow.
Kevin
motor module make error 网易邮件中心 via Tech-talk
Re: motor module make error Johnson, Andrew N. via Tech-talk
Re: motor module make error Kevin Peterson via Tech-talk
Prev: Re: [EXTERNAL] Data Browser (phoebus) auto data fetching from an Archiver Appliance Hartman, Steven via Tech-talk
Next: Re: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Prev: Re: motor module make error Kevin Peterson via Tech-talk
Next: Re:RE: motor module make error 网易邮件中心 via Tech-talk
