Subject: Re: Measurement Computing USB-1608G_2AO support
From: "Dudley, David via Tech-talk" <[email protected]>
To: Mark L Rivers <[email protected]>
Date: Sat, 23 Oct 2021 00:32:10 +0000
Yes, I have a working version of it, and I am working on making sure that it works properly.
I can read all the analog inputs, and they all seem to be correct and scanning correctly, next week I plan on working on the analog outputs, the counters, and the waveform generator. The thing does so much it’s just a lot to manage quickly.
I’ll let you know as soon as I am farther along on getting the completed version, and submit it either back on github or I’ll just email it directly to you.
Personally, I’m very interested in the USB-2500 for the next device I want to get supported.
Sent from my iPhone
On Oct 22, 2021, at 8:08 PM, Mark L Rivers <[email protected]> wrote:
[EXTERNAL] This email originated from outside of FRIB
Hi David,
Are you working on the mcBoard_USB-1608G.cpp glue layer I proposed?  If you put it on github I’ll be happy to take a look and collaborate via pull-requests when you are ready.  This is a board that has been on my to-do list.
I am about to start working on Linux support for the USB-3105 which has 16 analog outputs and 8 digital I/O for $550.
Sent: Thursday, October 21, 2021 6:38 PM
Cc: Hu, Yong <[email protected]>; [email protected]
It seems a pretty interesting device, and I’ve used it a lot using the windows software it comes with. I’m starting to get close on having the Linux support finished for it so I can then use it in Linux EPICS systems.
Hope it works as good.
Sent from my iPhone
Hi Yong,
Note that the analog outputs can also be triggered, getting their values from an waveform record.  So it can be used as an inexpensive waveform generator, up to 500 kHz for a single output or 250 kHz 2 outputs.
Sent: Thursday, October 21, 2021 4:51 PM
To: 'Hu, Yong' <[email protected]>; 'Dudley, David' <[email protected]>
Cc: [email protected]
Subject: RE: Measurement Computing USB-1608G_2AO support
Hi Yong,
The USB-1608G_2A0 accepts a TTL trigger.  It can thus be used as an inexpensive waveform digitizer using either the internal clock, or an external trigger to collect the next sample.  It can digitize a single input at 500 kHz, 2 channels at 250kHz, etc.
Sent: Thursday, October 21, 2021 4:43 PM
To: Mark Rivers <[email protected]>; 'Dudley, David' <[email protected]>
Hi Mark, David, etc.:
Those modules seem amazing. Do you know any analog I/O modules accept external trigger, i.e. it has an TTL trigger input?
Yong
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Monday, October 18, 2021 at 7:33 PM
To: 'Dudley, David' <[email protected]>
Cc: [email protected] <[email protected]>
Hi David,
The high level EPICS software already exists in this file, which works on both Linux and Windows.
https://github.com/epics-modules/measComp/blob/master/measCompApp/src/drvMultiFunction.cpp
The low-level Linux driver for the USB-1608G-2A0, written by Warren Jasper, also already exists:
https://github.com/wjasper/Linux_Drivers/blob/master/USB/mcc-libusb/usb-1608G.c
All that needs to be done is to write the “glue layer”, which is the derived class mcBoard_USB-1608G.cpp, in this directory:
https://github.com/epics-modules/measComp/tree/master/measCompApp/cbw_linuxSrc
There are lots of examples, including the mcBoard_E-1608.cpp that can be used as a starting point.
From: Tech-talk <[email protected]> On Behalf Of Dudley, David via Tech-talk
Sent: Monday, October 18, 2021 2:29 PM
To: [email protected]
Subject: Measurement Computing USB-1608G_2AO support
Anyone implemented support for these device under Linux?  measComp module looked real promising until read that only certain modules are supported under Linux, and this one is not one of them.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
JPEG image
RE: Measurement Computing USB-1608G_2AO support Mark L Rivers via Tech-talk
Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Re: Measurement Computing USB-1608G_2AO support Hu, Yong via Tech-talk
Re: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Prev: Re: motor module make error Kevin Peterson via Tech-talk
Next: RE: [EXTERNAL] Data Browser (phoebus) auto data fetching from an Archiver Appliance BENEDETTI Florian via Tech-talk
Prev: Re: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Next: RE: Measurement Computing USB-1608G_2AO support Mark L Rivers via Tech-talk
