Dear all, I use Control System Studio (CSS) in CentOS 7 OS and often meet no respond problem of CSS, when opening BOY containig databrowser widget to display history and live data of my monitor sites. I could always trigger the no respond problem like this: There are several button widgets for my monitor sites in the BOY, the databrowser plots for each monitor sites could be opened by clicking the button of the site. I could always trigger no respond problem of CSS after clicking several buttons to open several databrowser plots. I wonder do you meet the same problems and how to solve it. Any help or suggestions are appreciated and thanks in advance. The no respond error messages in terminal are shown as follows: 2021-11-02 16:20:30.969 SEVERE [Thread 1] org.csstudio.logging.PluginLogListener (logging) - Unhandled event loop exception java.lang.NullPointerException at org.csstudio.swt.rtplot.internal.TimeTicks$TickConfig.access$5(TimeTicks.java:60) at org.csstudio.swt.rtplot.internal.TimeTicks.format(TimeTicks.java:241) at org.csstudio.swt.rtplot.internal.TimeTicks.format(TimeTicks.java:1) at org.csstudio.swt.rtplot.internal.TimeAxis.drawTickLabel(TimeAxis.java:188) at org.csstudio.swt.rtplot.internal.TimeAxis.drawTickLabel(TimeAxis.java:1) at org.csstudio.swt.rtplot.internal.Plot.drawMouseModeFeedback(Plot.java:780) at org.csstudio.swt.rtplot.internal.Plot.paintControl(Plot.java:753) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:231) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5227) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1349) at org.eclipse.swt.widgets.Control.gtk_expose_event(Control.java:3390) at org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite.java:771) at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java:182) at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1993) at org.eclipse.swt.widgets.Control.windowProc(Control.java:5827) at org.eclipse.swt.widgets.Display.windowProc(Display.java:5498) at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method) at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:9545) at org.eclipse.swt.widgets.Display.eventProc(Display.java:1275) at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method) at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4149) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148) at org.csstudio.utility.product.Workbench.runWorkbench(Workbench.java:99) at org.csstudio.startup.application.Application.startApplication(Application.java:265) at org.csstudio.startup.application.Application.start(Application.java:119) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
