Subject: Re: Question about "Unhandled event loop exception, java.lang.NullPointerException“ problem of Control System Studio
From: "Wilson, Andy \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 4 Nov 2021 12:13:53 +0000
This sounds similar to this issue although the error messages are different: https://github.com/ControlSystemStudio/cs-studio/issues/2660
You would see this if you are using eclipse 2020-12.
Andy
From: Tech-talk <[email protected]> on behalf of lzfneu--- via Tech-talk <[email protected]>
Sent: Tuesday, November 2, 2021 13:13
To: [email protected] <[email protected]>
Subject: Question about "Unhandled event loop exception, java.lang.NullPointerException“ problem of Control System Studio
Dear all,
I use Control System Studio (CSS) in CentOS 7 OS and often meet no respond problem of CSS, when opening BOY containig databrowser widget to display history and live data of my monitor sites.
I could always trigger the  no respond problem like this:
There are several button widgets for my monitor sites in the BOY, the databrowser plots for each monitor sites could be opened by clicking the button of the site. I could always trigger no respond problem of CSS after clicking several buttons to open several databrowser plots. I wonder do you meet the same problems and how to solve it. Any help or suggestions are appreciated and thanks in advance.
The no respond error messages in terminal are shown as follows:
2021-11-02 16:20:30.969 SEVERE [Thread 1] org.csstudio.logging.PluginLogListener (logging) - Unhandled event loop exception
at org.csstudio.swt.rtplot.internal.TimeTicks$TickConfig.access$5(TimeTicks.java:60)
at org.csstudio.swt.rtplot.internal.TimeTicks.format(TimeTicks.java:241)
at org.csstudio.swt.rtplot.internal.TimeTicks.format(TimeTicks.java:1)
at org.csstudio.swt.rtplot.internal.TimeAxis.drawTickLabel(TimeAxis.java:188)
at org.csstudio.swt.rtplot.internal.TimeAxis.drawTickLabel(TimeAxis.java:1)
at org.csstudio.swt.rtplot.internal.Plot.drawMouseModeFeedback(Plot.java:780)
at org.csstudio.swt.rtplot.internal.Plot.paintControl(Plot.java:753)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:231)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1349)
at org.eclipse.swt.widgets.Control.gtk_expose_event(Control.java:3390)
at org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite.java:771)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java:182)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1993)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5827)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5498)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:9545)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1275)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4149)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.csstudio.utility.product.Workbench.runWorkbench(Workbench.java:99)
at org.csstudio.startup.application.Application.startApplication(Application.java:265)
at org.csstudio.startup.application.Application.start(Application.java:119)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Question about "Unhandled event loop exception, java.lang.NullPointerException“ problem of Control System Studio lzfneu--- via Tech-talk
Prev: RE: archiver appliance start failed Abdalla Ahmad via Tech-talk
Next: RE: archiver appliance start failed Shankar, Murali via Tech-talk
Prev: Question about "Unhandled event loop exception, java.lang.NullPointerException“ problem of Control System Studio lzfneu--- via Tech-talk
Next: ArchiverAppliance LTS to S3-Storage Heinz Junkes via Tech-talk
