Subject: RE: archiver appliance start failed
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: 网易邮件中心 <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 4 Nov 2021 11:30:26 +0000
Forgot to add tech-talk.
Sent: Thursday, November 4, 2021 12:35 PM
To:
Hi Liang
As long as the sampleStartup.sh script showed no errors the archiver appliance should be running. Can you please show the contents of appliances.xml file? Could be the IP addresses of the instances defined as “localhost” instead of your PC’s IP address.
Best Regards,
Abdalla.
From: Tech-talk [mailto:[email protected]] On Behalf Of ?????? via Tech-talk
Sent: Thursday, November 4, 2021 10:24 AM
To: tech-talk <[email protected]>
Subject: archiver appliance start failed
Hi all,
      I installed the archiver appliance using the instruction:  http://slacmshankar.github.io/epicsarchiver_docs/installguide.html
      the installation was good, but when I did: ./sampleStartup.sh start.
     Software: Centos 8(64),  Apache Tomcat/9.0.54, jdk 1.8.0_312
1)----------First -----------------
                 [iasf@localhost tomcat_instances]$ ./sampleStartup.sh start
                 ./sampleStartup.sh: line 9: /opt/local/setEPICSEnv.sh: No such file or directory
Then I uncomment the line, since (1) I could not found "setEPICSEnv.sh" file. (2)I have already set  EPICS_CA_ADDR_LIST=localhost, EPICS_CA_AUTO_ADDR_LIST=YES, EPICS_CA_MAX_ARRAY_BYTES=16384, JAVA_HOME, JRE_HOME,EPICS_HOST_ARCH=linux-x86_64,EPICS_BASE  in my own environment.
I do not know whether it was right.
2)---------------Second----------------( i did as "https://github.com/slacmshankar/epicsarchiverap/issues/41" said [ the LD_LIBRARY_PATH error], but nothing changed. )
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/mgmt
Using 64 bit versions of libraries
~/EpicsAA/tomcat_instances/mgmt/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/engine
~/EpicsAA/tomcat_instances/engine/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/etl
~/EpicsAA/tomcat_instances/etl/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/retrieval
~/EpicsAA/tomcat_instances/retrieval/logs ~/EpicsAA/tomcat_instances
It seems not good, and the  http://{MY_IP_address}:17665/mgmt/ui/index.html could not connect, it shows 404 code.
I check the firewall, it was stop.
What should I do it? why it did not start.
Cheers,
Liang
Re:RE: archiver appliance start failed 网易邮件中心 via Tech-talk
Prev: Archiver Appliance configuration questions Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Question about "Unhandled event loop exception, java.lang.NullPointerException“ problem of Control System Studio Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Prev: archiver appliance start failed 网易邮件中心 via Tech-talk
Next: Re:RE: archiver appliance start failed 网易邮件中心 via Tech-talk
