Yes, I didn't mention it, but I've opened TCP/UDP 5064 and TCP/UDP 5065.
On 11/5/21 10:53 AM, Paduan Donadio, Marcio wrote:
> Michael, this idea of using telnet was very useful. I ended up discovering that the firewall was blocking port 5064 in Ubuntu1. I've opened the port, could connect through telnet, but caget still refuses to communicate. I've tried both the broadcast address
and Ubuntu1 specific IP in EPICS_CA_ADDR_LIST.
Failure to connect w/ 'telnet' is good indication of a firewall problem. However, success only tells you that TCP traffic can get through. You also need to open up 5064 (and should open 5065) for UDP traffic.
- IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
- Re: IOC in Docker not responding to caget from another host Florian Feldbauer via Tech-talk
- Re: IOC in Docker not responding to caget from another host Lucas Russo via Tech-talk
- Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
- Re: IOC in Docker not responding to caget from another host Michael Davidsaver via Tech-talk
css could not start since java version changed 网易邮件中心 via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
