Hi all, Today I changed my jdk from 1.8.0 to 17.0.1. Then I changed and source the environment of JAVA_HOME. java version "17.0.1" 2021-10-19 LTS Java(TM) SE Runtime Environment (build 17.0.1+12-LTS-39) Java HotSpot(TM) 64-Bit Server VM (build 17.0.1+12-LTS-39, mixed mode, sharing) Now CSS could not be startup. I changed the version number in css.ini "-Dosgi.requiredJavaVersion=17.0.1", but not working. log file show that wht version was not changed. ---------------------------------log of CSS---------------------------------------- !SESSION 2021-11-02 16:28:57.514 ----------------------------------------------- eclipse.buildId=SNS_CSS java.version=1.8.0_312 # i think the version was not modified. css still use the old one. java.vendor=Red Hat, Inc. BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US Command-line arguments: -os linux -ws gtk -arch x86_64 ---------------------------------End --------------------------------------- Could someone tell me how to fix it? Cheers, Liang
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
