Randall,
tl;dr The EPICS nPoint motor driver does not currently provide a way to
execute a user-specified wavetable.
I took a closer look at the driver. The controller's wavetable
functionality is used internally to implement trapezoidal motion
profiles for every point-to-point move.
Specifically, the move method does the following:
1. generates the trapezoidal move profile:
https://github.com/epics-motor/motorNPoint/blob/4d8b0d1cc0dc78315f8dad1279fd53a1e4cac0ce/nPointApp/src/LC400MotorDriver.cpp#L732
2. writes the trapezoidal move profile to the controller:
https://github.com/epics-motor/motorNPoint/blob/4d8b0d1cc0dc78315f8dad1279fd53a1e4cac0ce/nPointApp/src/LC400MotorDriver.cpp#L737-L738
4. runs the loaded waveform:
https://github.com/epics-motor/motorNPoint/blob/4d8b0d1cc0dc78315f8dad1279fd53a1e4cac0ce/nPointApp/src/LC400MotorDriver.cpp#L798
The wavetable records in LC400_auxParameters look like they are mostly
used as readbacks. I don't know how helpful the output wavetable
records are.
Asyn model-3 motor drivers like the NPoint LC400 driver can implement
profileMove methods which allow users to specify desired positions in an
EPICS waveform:
https://github.com/epics-modules/motor/blob/6d127cd6f433ff34256a53d6e7ff0309cc741dad/motorApp/Db/profileMoveAxis.template#L32-L42
The profileMove screens in the motor module look very similar to the
trajectoryScan screen here (trajectoryScan sequence programs pre-date
asyn model-3 motor drivers):
https://epics-modules.github.io/motor/trajectoryScan.html#MEDM%20screens
Kevin
On 11/8/21 14:47, Randall Cayford wrote:
Thanks Kevin.
I’ve got those records but I’m not clear on what you mean. None of those PVs appear to set a wavetable entry. Are you saying that the current implementation only allows keeping the wavetable in the outside program and issuing a series of moves by setting the val motor field, waiting, and setting the next? So not using the ability of the nPoint to do custom wavetables at all? Is loading a custom wavetable what you mean by profileMove isn’t implemented?
Randall
- nPoint motor driver Randall Cayford via Tech-talk
- Re: nPoint motor driver Kevin Peterson via Tech-talk
- Re: nPoint motor driver Randall Cayford via Tech-talk
Re: Re:Re: Re:RE: archiver appliance start failed Han Lee via Tech-talk
RE: EPICS support for the Omega Platinum Series PID Controllers Sobhani, Bayan via Tech-talk
<2021>
2025
2026
css could not start since java version changed 网易邮件中心 via Tech-talk
<2021>
2025
2026
